Custom Battery packs? Anyone make them?
  • photohoward1
    • 1610
    Does anyone make custom Lipo battery packs? I have a tight space I need them in. Or can I buy single cells from anywhere and assemble myself?
  • RaceMechaniX
    • Sep 2007
    • 2821
    Howard,
    You can try Junlin at Roaring Top or Mark from Dinogy can usually build custom packs.
    I believe Roaring Top will also sell you single cells and you can assemble.
    Tyler
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • Hydrocarbon82
      • Apr 2016
      • 86
      Here's the chart, but doesn't show price: http://www.roaringtopusa.com/customer-assemble
      Size increases nearly linearly with capacity, discharge rate by 50% the increase. If you do make your own packs, I'd recommend getting some single sided copper PCB board. Most good lipo's connect the tabs thru slots in a pcb board to greatly reduce the wires wiggling the tabs. Also ask if they're pre-tinned or need nickle-compatible solder & flux.
      If you find pull apart your own battery, use acetone & dental floss to separate cells. Then cover each tab you aren't working on with kapton tape. Also drain the battery to about 0%, less charge will reduce the danger a hair if there's an accident.
