Anyone using it? Anyone know of any reviews or video demos? From the English on the instructions I can tell this is a Chinese product but if it works well, I can see me ordering one once they get them back in stock.
RCM Telemetry
Yep, I've been using too. Here are a couple of screen shots of runs. It is quite a useful tool to help with tuning.
Screenshot_2017-08-08-17-50-14.jpgScreenshot_2017-10-24-07-26-25.jpgScreenshot_2017-10-24-07-26-44.jpgNZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
Yes generally my batts are hottest after a run. The alarms work but you need to have your android device with you to hear them. No it only works in portrait. The range seems ok, but I was losing the wifi at the top end of our pond at approx 200m from the reciever unit, but that could be a localised issue.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
Yep pretty well. I have been experimenting with my Pursuit for endurance, and the alarm was going off well before LVC. In fact I have the LVC set at 3.4V and the alarm was going off at 7.2v (the telemetry sees 2S from the balance lead) and the lvc was not kicking in, even running down to 7v no lvc due to the low current draw. Makes the alarm handy.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
I am curious as to the maximum voltage input this system is designed for. Most likely it was designed for aircraft monitoring and has been adapted for marine usage. At 12 volts maximum input how does one use the system with voltages greater than this. I assume a person interested in telemetry for their boat would be using far higher voltages.
While the manufacturer states a maximum 12 volts input the item description on the OSE store website states "Battery Voltage up to 14.4 volts (4s lipo)". With such a low voltage input how useful is the system or am I missing something as the voltage maximum input seems to be very restrictive in how the system is applied.Comment
The system is powered either from a 2S lipo or life, or from the balance plug on the main battery, which is what I do. This only taps two cells for power due to the plug included.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
Peter,
many thanks. Thus either the balance plug connection as shown on the pdf download or a standalone battery are used. My son wishes to use 6s (two by 3s in series), so I assume he simply taps into the balance plug on one battery to power the setup. From my reading it seems the telemetry is sensing just two cells when detecting lvc as I was confused by setting the lvc to 7.2 volts for the alarm.Comment
This is my son's Exceed "Flowmaster" 650 with RCM telemetry just added. Boat is awaiting its maiden run. TP Power 2940 1790kv with 35 mm 2-bladed propellor running on 6s. I must say this has been quite a task for him to fit everything in a relatively small hull. First task was to strip the stock hull and fit a carbon fibre inlay plus carbon fibre reinforced filling on the tips.Attached FilesLast edited by Old School; 10-27-2017, 09:06 PM.Comment
