I've had my Genesis for a several years now, got a wealth of experience on it, let me know if you have any specific questions that weren't already answered for you. Below are my specs...
SSS 4082 2000kv on 6S
Hobbyking 180a V3 ESC w/ 8mm Castle Connectors
Reinforced hull and hatch with fiberglass cloth layup
Keith Bradley hatch lock kit
3/16 Flexshaft Conversion (Kintec 3/16 strut)
Octura M445 prop
Turnigy Heavy Duty 3S lipos run in series
Dual Pick-Up Rudder
4mm I.D. Cooling Lines
Big thing I recommend is reinforcing the hull if you plan on going faster than 50 mph. If you don't reinforce the hull, it will crack after your first few flips at speed. It's super easy to do fiberglass cloth layup, or carbon if you want to get fancy. Also, highly recommend you use hatch bolt system instead of just tape.
Here is a video of my boat with my older previous 4082 1600kv motor, it only got about 65 mph with that setup, it's currently doing over 70 mph with the setup it has now. The stock SSS 36mm motors are not known to be very reliable, however, their 4082 2000kv/2200kv motors are very good. I've had them in my Genesis and HPR 115 dual drive with no issues.
Octura M445 prop
Dual Pick-Up Rudder
