I guess I need some new parts for my Genesis...
My strut bushings seems to have worn out.
And the stuffing tube teflon doesn't look as happy as it could be!
The prop shaft with 4mm square drive is done also.
What should I get and from which retailer to replace them?
Should I change to 3/16” drive since it seems like essentially all parts are going to be replaced? 4mm has treated me pretty well, but maybe its cheaper, better and easier to get?
Is there a kit with all the necessary parts to change over from 4mm to 3/16" on a Genesis?
Do they make a bearing strut for 4mm driveline compatible with the Genesis?
Is there a stuffing tube that is easier to grease? Or is there a way to make a standard one easy to service with lubrication? As well as is there a better interface for stopping water propagation through the drive shaft?
Anyone that has replaced these parts have some good advice for better longevity and durability ?
Can I buy just a offset bracket for the rudder while I am in there playing around?
Does anyone have strong opinion on a offset rudder "Z" adaptor, or having a secondary mounting point as pictured?
