24" and 27" cat single motor setup
  • jopher
    • Aug 2017
    • 9
    what is the best motor (brushless), ESC, strut, prop, rudder, and shaft and shaft housing?
    any idea that would help..
  • Insanity Plea
    • May 2017
    • 562
    A wealth of knowledge can be found using the search block in the upper right corner. I don't know what boat you have but I remember seeing right much info on the blackjack 24.
    IMPBA 20583
    • fweasel
      master of some
      • Jul 2016
      • 4286
      I have a 27" cat that does 92mph on a TP 3080kV motor, 220A Swordfish ESC, speedmaster mini strut, speedmaster 006 mini rudder, ABC 1715, 3/16" flex cable, 1/4" K&N bass stuffing tube
      Vac-U-Tug Jr (13mph)
      • ray schrauwen
        • 9472
        On 4S?
        Nortavlag Bulc
          Jopher, we need a lot more information to give you a useful answer.
          - what speed do you want?
          - what runtime do you want?
          - what type of running, oval racing, general sport running, speed runs?
          - what voltage do you want to run?
          - what size pond do you run on?
          - smooth water, ripples, waves?
          - what is your budget?
          Ray the math says it could have been on 4S....
          • MadProps
            • Mar 2017
            • 236
            there are the appropriate questions
            • fweasel
              master of some
              • Jul 2016
              • 4286
              Yes on 4S
              Jopher, the point of my answer was you haven't given us enough to go on, just like my answer really doesn't give you much of a road map either
              • jopher
                • Aug 2017
                • 9
                60mph+
                id like it single prop setup
                4s batt
