Whew. I thought you sank the mini Rivercat for a second there. I started to get sink lol. I'd hope it wouldn't sink. I don't think the hatch would come off no matter what and there's foam where foam will fit. Sorry for your loss but try to add more floatation in all your boats. If the hatch comes off, that's a big problem however, pool noodles will come out unless they are stuffed in there tight. A good idea is to get some of that black pipe insulation and put that on top of the batteries before you put the hatch on.
I learned a valubale lesson in flotation today...
I have a couple of gators in my backyard pond but not big enough to concern me. . .not yet. I go in the water too when I run my boats and have occasionally retrieved my boat by wading in the water. . .chest high. It was when I had a boat starting to sink on the deep end that I was worried because I didn't know what was beneath me. . .scary and will never do it again.Comment
i did have an issue once where my boat hit something in nice clean water , there were no logs or anything floating in this small lake but when i brought the boat into shore i noticed the rudder was slightly tilted up and the prop had a mark on it, this was a new polished prop and the rudder had a saver on it so there must have been some type of fish / turtle or whatever in this fresh water that my boat hit.Comment
A few years ago at one of the big races, we had a boat do that. Everyone thought it was gone after about 5 min.
The next day during a race, the CD yells "Dead Boat in turn 3"
Well with 5 drivers on the stand and 5 boats still racing, we all said "WHAT"
It was the boat that went down the day before, It was over 10 ft. deep in the section of the pond.
When you saw the large eruption of air bubbles, was there a little bit of white smoke with it??
I have seen this happen from batteries under water.
LarryComment
My old Shockwave 26 did a similar act and I also got it on vid. However you could see the very long but low waves it lifted off of. In my case it turned a bit and ripped the hatch off so it didn't spear the bottom.
If you slow your vid down, you can see it seems to hit an invisible wave. The bow angles up a bit, then the stern does the same and rotates the bow down. Muck is incredibly powerful so it's possible the hatch was partially covered in it, then finally released. I'd bet if you found it by dragging an anchor, the flotation inside may be enough to raise it if disturbed.Comment
This is the reason I now fill the bow of all my hulls with two-part expanding foam.
1.) Added flotation.
2.) Structural rigidity.
3.) Reduces the interior air cavity and lessens the chances of blowing out a seam when hitting the surface, after going airborne.Comment
Has anyone tried that insulation foam in a can you spray into crevices? I'm a bit concerned about that expanding foam stressing the seams on the hull... But it does have excellent flotation properties and it won't break free, unlike a pool noodle...Comment
Yes. Do not use that. It utilizes oxygen to cure and it takes a very long time for the center to cure resulting in a very deformed hull when it expands. I know this from experience, ruined a hull once. I also did testing by doing a small amount at a time. Still does not work. Composite envisions on eBay sells two part foam which cures from a chemical reaction instead of an oxygen reaction. HOWEVER, it will suck a hull inwards if you left it rise from bottom to top. You have to leave a gap or some way to let the foam release. Maybe put a carefully cut wax paper or maybe a plastic bag.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
1) DO NOT FILL AN ENTIRE EMPTY PORTION OF A HULL ALL AT ONCE. THE MIDDLE WILL NEVER DRY...this is where most people screw up and bitch about the product being garbage.
2) Add about a softball size blob of the foam and let it cure/expand for a day....repeat as often as needed to fill the desired void..be patient..don't rush..if it takes a week or so to do a large void..then so be it.
3) That's all there is to it.
I currently have 15 FE boats done this way, from P spec to 10S boats (as well as another 20 or so over the years) with NO issues whatsoever. It makes a flimsy hull rock solid and makes a strong hull almost indestructible. It does NOT absorb water as many claim, even if the hard shell has been cut open. Take a bite of an Aero chocolate bar and see what I mean if you don't believe me.
It does discolor a bit when exposed to sunlight...oh well.Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
It can be used safely if you know what you are doing...
It does discolor a bit when exposed to sunlight...oh well.Comment
This has been my product of choice for the past 5 years...
Before that it was Great Stuff low expansion.
I've heard that the two part foam expands quickly so be careful...I've never had a chance to try it.Grand River Marine Modellers
