This U-cup seal I found is keeping all the water out, and all the grease in. Seems we need to collaborate and put our ideas together. I do not want water in there! Cleaning that driveline really sucks and it's dirty... I ran about 12 good runs with the seal on it and took it apart. Not a lick of water and the grease looked like when I put it in. I would love to try the bearings and the seal, see if we can make both our setups better. I pm'd you on it... many probably think we are wasting our time, but I see less friction and less maintenance! I'll pm you my email, it's much easier than the site... Lets do it!!!
Strut bushings
This U-cup seal I found is keeping all the water out, and all the grease in. Seems we need to collaborate and put our ideas together. I do not want water in there! Cleaning that driveline really sucks and it's dirty... I ran about 12 good runs with the seal on it and took it apart. Not a lick of water and the grease looked like when I put it in. I would love to try the bearings and the seal, see if we can make both our setups better. I pm'd you on it... many probably think we are wasting our time, but I see less friction and less maintenance! I'll pm you my email, it's much easier than the site... Lets do it!!!32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Are those Boca bearings? Do you have a P/N I could look up? Wondering how I missed those... Travis, what about unsealed bearings and let the lubrication flow thru the bearing stack, then let the lip seal stop the water and keep the grease in? My concern is the life of the bearing running as fast as we do and relying on factory grease. Are you getting long run time on those? Maybe I'm making it too hard, but it is working well. As long as those Bushings have good lube, I'm not seeing any appreciable wear.
I use a pair in my Cheetah.
They are not waterproof. I could be wrong about all Boca has in stock. I would love to know where these roller bearings come from.Nortavlag Bulc
Ray, Boca has open and sealed versions. The "sealed" version is not waterproof. If there is water in your strut, then the ball bearing may not be your best bet. Jay likes the floating bushing, and for a wet setup, I agree. Sealing the strut requires machining and some figuring out. I wish Speedmaster sold a sealed version. I'd pay more not to hassle that grimy flex shaft as often!
BTW, water will just eat up Lead/Teflon bushings... If using, bring some spares! A floating bushing has much more bearing area, so it resist the bad effects of water much longer.Comment
Travis, you didn't send me your email, I'm heading out to the lake now. Here's a PDF of the concept we can kick around. Have a good time out there!Attached FilesComment
Yes you want at least 2 ball bearings back to back at the rear of the strut to take side loads otherwise I have found a single ball bearing at the rear wears excessively. You can get away with a single ball bearing at the front of the strut.Comment
I like overkill so I don't have to worry with it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
When you say roller bearings it made me think of these https://www.bocabearings.com/product...?ProductType=0 I used in my Cheetah strut. I don't have enough run time on them to actually recommend them but since it was a direct fit into my large Octura strut I thought why not??? I hold them in place with the red retaining compound I got from the free bee bags every Michigan run I've gone to.
Two of these to be exact: https://www.bocabearings.com/products/sce36tn-660
I like the rubber seal on the PDF. I can machine what is required. Where do you get the rubber seals? Part number for the lazy.Nortavlag Bulc
We shall see how long they last. If they fail, I will go to roller bearings maybe or just shim it to Speedmaster.Nortavlag Bulc
BTW, water will just eat up Lead/Teflon bushings...NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
Note: requires a 5/16" counterbore. The seal is 0.065" thick, counterbore needs to be 0.060" to properly load the seal. That means the total depth on that drawing should be set to 0.160", 0.060 for the seal and 0.100" for the stop in the back. Very low friction with this type of seal. I don't have any water in my strut using it.Comment
The teflon on these Bushings from OSE is a very thin veneer of teflon, bonded to the metal. I've found and others have reported that this veneer goes away very quickly. They, however, do not have sealed struts. I run 3 bushings, with a 3/8" gap in between in a Speedmaster 21 strut. I have well over 20 runs on this setup and the bushings are as tight as when I put them in. The grease stays in, so when the boat comes back in, there's no side play on the strut. Now, I have np proof that the exclusion of the water is the reason for this longevity, but the circumstantial evidence is pretty strong. When I first put the bushings in, I didn't have the seal, and the veneer was gone in the end bushing after the second run.Comment
