Vac-U-Tug
  • rayray9
    Steve Takes My Money
    • Sep 2016
    • 98
    Vac-U-Tug
    Decisions, decisions, decisions. Vac-U or Zipp Kitts, pulled the trigger on Vac-U, Phil been great order shipped form Georgia to New York looking at this Monday.
    Anyone has some inside info on this tug? Going to use this as a recovery rig & long day runner.
    Third hull on the bench from scratch, need to clone myself.
  • pescador
    • May 2009
    • 499
    I've had the Vac-U-Tug and still have a Vac-U-Tow that's been doing rescue work for a few years. The Tow is great, it fits in a toolbox that makes it super easy to pack.
    Sent from my iPad using Tapatalk
    Namba District 16
    • rayray9
      • Sep 2016
      • 98
      Awesome pics, yep - recovery boat will be my intensions. From the homework I have done I'm told 7 hours run time on a 2S Lipo is this possible?
      Might be a runner with my son's Alpha Patrol boat, 2S 5000 Venoms hardcase
      • Navherc130
        • Sep 2013
        • 151
        We also use a vac-u-tug. Have it running on a 7 cell nimh 5000mah venom battery. Just a tad more speed. Ours is more simple, we tow a short length of floating fly line with a tennis ball. Do the wraparound and pull in! Floating line really helps.
        • fweasel
          master of some
          • Jul 2016
          • 4281
          I use one as well. I have the bigger brushed motor with the two blade prop and it pushes my bigger boats in fine. The stern rides very low in the water, so if you build a rescue raft for it, it needs to maintain that same attitude or the prop cavitates. I started with a ball and fishing line, but got it stuck in the prop and switched to the raft. I run mine on a 7 cell pack.
          Vac-U-Tug Jr (13mph)
          • pescador
            • May 2009
            • 499
            I'm using two 2200 mah 3s lipo's in parallel and have never used more than 25% rescuing for our clubs practice days.
            Namba District 16
            • rayray9
              • Sep 2016
              • 98
              Flyfishing line floats right?
              • pescador
                • May 2009
                • 499
                There are different fly lines some float or sink or have different combinations of sink tips. Usually if it's a bright colour it's a floating line. If your buying a cheap one get a DT (double taper) so you can use both ends. The higher the # the thicker the line.
                My other hobby lol.
                Namba District 16
                • rayray9
                  • Sep 2016
                  • 98
                  Good info, thanks.
                  Deciding between a pvc pipe / conduit system or a flotation device & drag line.
                  Me & fly fishing don't mix, wrestled an alligator once and he won, in New York of all places.
                  • pescador
                    • May 2009
                    • 499
                    I use the pvc pipe rig most of the time, our pond can get weedy and the drag line can get hung up. I just switched the rig over to my Atlantic Tug that is repowered and modded quite a bit but it's faster and has more grunt to get out of the weeds.
                    Namba District 16
                    • rayray9
                      • Sep 2016
                      • 98
                      Aquacraft Atlantic Tug?
                      • Prodrvr
                        • Jul 2015
                        • 701
                        Use the tug pulling the balsa float with hooks on it, floating fishing line. Circle dead boat, hooks on float catch the rudder and tow it in.
                        • rayray9
                          • Sep 2016
                          • 98
                          That thing is crazy, might gaff a shark
                          That's one nice tug.
                          • pescador
                            • May 2009
                            • 499
                            Yup, I won it at the Nats a few years ago and put a bunch of stuff in it, repowered with the Fireboat motor, servo controlled water cannons, sound, bilge pump, modified the keel for a bigger prop. It just about does a wheelie taking off. :) I was bored that winter lol.
                            Namba District 16
                            • rayray9
                              • Sep 2016
                              • 98
                              Nice prize on NATS
