Leopard 4082 1600 ?
  • dtacmed
    • Mar 2008
    • 199
    Leopard 4082 1600 ?
    Is the Leopard 4082 1600kv a Y wind ? Trying to figure out timing. I know its on here somewhere been looking just keep hitting all around the answer. Thanks.
  • CraigP
    • May 2017
    • 1464
    I think it's 8.5 degrees on Y, 0 degrees on D
    • CraigP
      • May 2017
      • 1464
      Oh and yes, it's a 2Y winding...
      • Drkrieger
        • May 2017
        • 69
        Don't mean to hijack, but then off the model number of this one.
        http://www.valuehobby.com/power-syst...-inrunner.html
        says 3674/3D. So would it be a safe assumption that it is a D wound motor?
        Messing with timing too
        • CraigP
          • May 2017
          • 1464
          OP posted it was a 4082 1600kv... can the OP verify the motor number?
          • martin
            • 2887
            Y wind 10 - 15 degrees, D wind 0 - 5 degrees.
            • martin
              • 2887
              Yep D wind.
              • Drkrieger
                • May 2017
                • 69
                sweet. Thank you. That may explain why the big prop was a lot for it to handle. was left default at 15° timing on the ESC. quite a bit for that motor
                • CraigP
                  • May 2017
                  • 1464
                  I'm missing something here or I need more coffee... Didn't the OP state it's a Leopard 4082 1600kv? I feel like I fell off the bus!
                  But thanks for the timing info.. that might explain why my motor, a Leopard 4082 1250 2.5Y wind, is running slow. I left it at zero, had a D wind in it before
                  • CraigP
                    • May 2017
                    • 1464
                    Oh I see, Drk asked about his motor...
                    • MadProps
                      • Mar 2017
                      • 236
                      while you guys are looking into this thread...I just bought a pursuit with the stock SSS motor is that a D motor?
                      thanks for looking
                      edit : HK specs 3660 size 1620kv
                      • dtacmed
                        • Mar 2008
                        • 199
                        Maybe I was not clear. I have a Leopard 4082 1600kv is this a Y wind ? and if so what would be the recommended timing ? Thanks
                        • Drkrieger
                          • May 2017
                          • 69
                          the actual model number is what would help. Then you can determine "Y" or "D" wound.
                          It would be the timing of 0-5 for "D" wound 10-15 for "Y" wound. just going through this myself with a different motor.
                          • martin
                            • 2887
                            This is a Y wind motor,you can use 10 - 15 degrees.
                            • CraigP
                              • May 2017
                              • 1464
                              I did look it up, on post 3. It's a 2Y, so use the Y timing, I'd start at 12 degrees, half way in between the recommendation...
