Im not familiar with inboard drive lines my only experience with rc boats has been outboards....then I bought a genesis and the stuffing tube wasnt epoxied in place on the hull bottom ...just a big hole to leak water ....not certain how where how long the the flex shaft & liner should be, I didnt want to epoxy what I had here so I just hot glued the hole closed to test run the boat
everything is stock on the genesis I have it tuned well and have been running a 42 mm prop on 6s ....now want to address this hole in the hull bottom epoxy a tube in place proper and get a better understanding of the liner & shaft
the liner rotates on the flex & rides up the shaft and touches the collect after a run ...should it do this?
the liner is 4 inches shorter than the flex shaft is this OK? or should it be the entire length of the flex shaft?
I also have a 40 size leopard 2000kv to upgrade but I read most upgrade the flex shaft to 3/16.....
the stock shaft has been holding up very well so my question is ......is the leopard motor capable of so much more torque that I must upgrade the shaft to 3/16
if infact I pretty much must upgrade the flex to 3/16 I want to know more about the drive line since I cant trust what came out of the Genesis knowing the assembler was a slacker
thanks for looking
thanks for looking
