I need a hull for my new motors
  • Sheffield
    • Jun 2017
    • 33
    Hello,
    A friend gave me a set of two 3682 - 1700kV motors, twin setup.
    First question is about the batteries, 5S or 6S regarding the 1700kV ?
    Second question, what size for the hull ?
    Thanks
  • Speed3
    • Mar 2017
    • 371
    If in a single setup. 6s, and a 30 to 33 inche mono.
      Twins scream out for a catamaran, better suited than a mono (although they can be made to work). A cat in the range of 36" to 40" would be a good choice, depending on the performance requirements (speed and run time). I assume HK EDF motors, they are long enough to have decent torque for 36mm cans. On 6S expect around 32,000 rpm loaded, if they will turn x447 props then speeds should be in the 60s.
      • Nevs
        Sven
        • Sep 2011
        • 164
        8s.442-447 in a 36" cat... 6s. 447 in a 40" mono..
          • 7673
          Delta Force Explorer hull. Twin cat! Add a couple of the Raider 150 ESC's.
