speed passion motor in a miss gieco 29
  • Drkrieger
    • May 2017
    • 69
    I have a Miss Gieco 29, and a monster motor that looks would fit. My question is if the diameter is correct, would this motor be a good upgrade
    It has tons of power
    does the stock water jacket come off the dynamite motor easily?
  • Erroneous
    • Apr 2016
    • 451
    If it has a smooth can (boat) not like the heatsink can (car) in the link. 2700kv 6s?..Needs to be under about 2,800 watts for the stock ESC. Water jackets are funny in that one manufacturer will list their motor as a 40mm can but its actually 38-39.something so good luck with that. At that price point look up TPPowerUSA.<free jacket
    • Drkrieger
      • May 2017
      • 69
      it is a heat sink type can. But i have seen many people running castle motors that are heatsink cans, and have water jackets on them.
      Does the water have direct contact with the motor?
      • Speed3
        • Mar 2017
        • 371
        2750kv is way to high if you plan to run above 3s. The miss gieco 29 need something like a leopard 4074 or 3674. A 4074, 1800kv would make for a high revving 6s setup. An octura x442, x642 would be good props to try.
        • Erroneous
          • Apr 2016
          • 451
          Yes, the water and seals contact the motor. And Castle/NEU?
          • ray schrauwen
            • 9472
            There are so many other motors more suited for boats. You would need a custom cooler for it if HRC can make one.
            Nortavlag Bulc
            • rol243
              • Apr 2017
              • 1038
              there are 2 types of Castle Neu motor cans, the 15 size [ 40 mm ] has raised fins and the 14 size has indented fins. O.S.E. has the special cooling jacket to suit the 15 size motors and you can use just about any 14 size [ 36 mm ] cooling jacket. what i do with all cooling jackets to be on the safe side is after i fit the cooling jacket to motor i run a bead of silicon sealant around the edges to asure no leaks occur.
                As above, stated that sensored motor is not a good choice for a 6S boat. The motor connections are not high-amp rated like more appropriate motors have and the Kv is far too high. The motor's "tons of power" will be converted to smoke and flames soon enough.
                Save it for your truck and buy a more suitable motor, like a 36x74 size with a Kv between 1500-1800. The former for longer run times and less heat, the latter for speed with shorter run times.
                • Drkrieger
                  • May 2017
                  • 69
                  Thanks everyone for the help. I am awaiting a 160 amp ESC, and will likely get a TP power motor, or the Leopard 4074 1650KV
                  • Mxkid261
                    • Jun 2015
                    • 734
                    Go with the TP. My buddy has a 4050 1520kv in a 29 geico and its quick on 6s.
                    • Erroneous
                      • Apr 2016
                      • 451
                      Turnigy 180 and :edit :edit. in mine. Thing is absurd. I'm still in the tuning phase so havnt GPS it yet
                      • rol243
                        • Apr 2017
                        • 1038
                        Originally posted by Erroneous
                        Turnigy 180 and TP4050 2100kv in mine. Thing is absurd. I'm still in the tuning phase so havnt GPS it yet
                        hope your not running 6s power with that combination. high kv motor for 6s.
                        • Erroneous
                          • Apr 2016
                          • 451
                          Ive been known to be stupit. Spinning a Dasboata ABC 1516 btw.
                          • Erroneous
                            • Apr 2016
                            • 451
                            Apologies for that info.... Im also an idiot.... Im running a Poseidon 1515 2200kv. The TPs are going in the Zelos.
                            • rol243
                              • Apr 2017
                              • 1038
                              i am doing a jae rigger powered by a new 1415 - 2400 kv / turnigy 180 / 5000 - 4s lipo. should be interesting when i find a suited prop. thinking on starting with an abc-h4 and working it from there.
