33'' mono twin setup
  • Nevs
    Sven
    • Sep 2011
    • 164
    if money matters you could get aprox. the same power by using these. https://hobbyking.com/en_us/rotorsta...size-heli.html
    And they are not 14 pole, but 6. I know the "new" T-180 works perfect with at least up to 8-pole.
    • Sheffield
      • Jun 2017
      • 33
      Well, I never used outrunner motors, the guy sells the 2 Scorpion 3026 - 1900kv for 100 us£ , they are new in the box, never used.
      Or I saw those 3650, same size than the Scorpion :
      Did you look at Dr Mad Thrust 2970 / 2200kv inrunner motors ? I had one in my hands magnets are very strong but 2200kv ...
      Nevs, the Rotorstar 1600kv look strong too, thanks for help guys.
      • ray schrauwen
        • 9475
        YOu can get just as good for about $50-$60 US Suppo motors.
        Altitude Hobbies is your source for the best remote control (RC) aircraft products including drones, motors, ESCs, lipo batteries, servos, adhesives, and parts. We are a leading retailer for top brands such as T-Motor, Leopard, DJI, Autel, Teledyne FLIR, JZ, CZI, Suppo, ZTW, HobbyWing, EMAX, APC, Xoar, and many more!
        Nortavlag Bulc
        • ray schrauwen
          • 9475
          Scorpions are a good deal.
          Nortavlag Bulc
          • Sheffield
            • Jun 2017
            • 33
            Those SUPPO motors look great , I didn' t know them. I add the link in my favorites.
            I think I will buy the NOS Scorpion 3026 1900kv.
            • Rcsurfrider
              • Jul 2017
              • 34
              Ive been using heli motors in my Rc jetboat using 28mm kmb drive. Tiny little motors 12pole 2836 with 700 watts and gobs of torque. I can jump it out of the water to clear rocks going upstream. My other jet boat uses a 3656 in runner . I really like how the outrunner boat motor handles better. I use a high pwm 60a heli esc with it, the esc has an added water cooling plate and it is fully water proofed. So I can run 80A continuous through it now and it stays cool:) The heli esc/ motor seems to give better throttle control compared to my inrunner setup, especially when river crawling.
              Im a big fan of outrunners as they are torquey has hell and self cool needing only a water cooled motor mount, which is standard for me.
              • RunningBeer
                • Aug 2014
                • 90
                Hi Sheffield, have a look at the photo galleries on my page, I've built a twin pursuit and a twin pirate. I also don't think 29mm motors will disapate enough heat for you. My pursuit had 2x HET 2200KV 3668's on 4S. The boat was a bit wild, there's a lot to learn about twins (like all boats).RB
                • Sheffield
                  • Jun 2017
                  • 33
                  #23
                  Thanks, pictures help me a lot, I will install the blade behind the propellers and motors low as possible.
                  • Sheffield
                    • Jun 2017
                    • 33
                    #24
                    I will use flex shafts with 3/16'' prop shaft .
                    Which one should you use ? 4mm flex shaft with 3/16'' prop shaft or 3/16'' flex shaft with 3/16'' prop shaft ? Thanks.
                    • RunningBeer
                      • Aug 2014
                      • 90
                      #25
                      I'm a 3/16 man myself. I guess it kinda matters what you have in the ol' prop box.
                      • Sheffield
                        • Jun 2017
                        • 33
                        #26
                        I made a motor mount for two Scorpion 3026 1900kv, the two parts are strongly glued using threated shafts in the holes + epoxy . It is strong enough.
                        Picture with the modified TFL rudder, motors will be low a possible in the hull .
                        • Nevs
                          Sven
                          • Sep 2011
                          • 164
                          #27
                          It looks great..And the shafts between the 2 mounts is another great idea..I have done this a couple of times but used a 1 piece 3mm aluplate...Your mount will be lighter..
                          • ray schrauwen
                            • 9475
                            #28
                            You can only get one threaded shaft between those mounts to join them no?
                            I've seen it done before but not sure how it was done???
                            Nortavlag Bulc
                            • CraigP
                              • May 2017
                              • 1464
                              #29
                              Nice, very close mounting! Have you thought about a small carbon fiber piece going from the point of the joint to the hull? That would triangulate that mount nicely! Could be epoxy attached the the motor mount I believe...
                              • Sheffield
                                • Jun 2017
                                • 33
                                #30
                                What do you think about those stingers ? I will order 2 stingers for 3/16"" shafts, any suggestion is welcome
