aeromarine conquest
  • TRUCKPULL
    • 2969
    Originally posted by urbs00007
    larry, can you recommend props for good run time yet fast enough for fun.? when running reverse cable do i need reverse cable collet? was going to run 2 octura flex hex as i already have one. thanks for the help.
    Props - ABC 1815 -17-45/2 Left and Right - get them from Dasboata B + S
    Left and Right Cables - Reverse collet is NOT needed
    Larry
    • TRUCKPULL
      • 2969
      John
      You will need a big rudder also
      The stand off on mine is 5 1/2" to the front of the blade.
      Blade is 6'' long
      I also use duel servos for the rudder - they can be seen in post #11
      You will also need a piece of plate (carbon fiber, Aluminum, or something else) to put below the lip on the hull to give you a flat area to mount the rudder.
      Larry
      • urbs00007
        • Jun 2011
        • 826
        thanks larry. will order those props right away. one thing different i will do ( need to reduce spending) I'm going to use speedmaster struts I already had. I will use teflon in shaft tube and remove brass where the tube goes thru transom to allow for a little adjustment. thanks again , larry.
        • urbs00007
          • Jun 2011
          • 826
          Originally posted by TRUCKPULL
          Both ESC's see 5S - 10,000
          Batteries are held in with Velcro , the pool noodle helps hold it in place.
          Struts - https://www.offshoreelectrics.com/pr...os-stinger-str
          Larry
          larry, thanks again for the suggestions. especially the esc wiring. never would have occured to me. one more question if you dont mind. if i lay my speedmaster struts flat on the table and set up from there, will I be in the ball park?
          • urbs00007
            • Jun 2011
            • 826
            boat is almost ready. waiting on motor ( one was defective ). question on cap banks. one controller seaking 180 (v2) has the original tethered cap bank. the second esc has an etti lv cap bank with 10 35 volt capacitors. will i be allright running the esc''''s this way?
