Genesis and spartan
  • Dudleydoright151
    • Jun 2017
    • 9
    Genesis and spartan
    Just picked up both of these today for $350 what do you think and what are some basics I should know about them I am new to boats but no rc.
  • fweasel
    master of some
    • Jul 2016
    • 4286
    Good deal, for sure. The Spartan is a money pit, the Genesis has room to grow. Sell the Spartan, use the funds to upgrade the Genesis as needed/desired.
    Vac-U-Tug Jr (13mph)
    • Dudleydoright151
      • Jun 2017
      • 9
      The spartan has a castle motor in it just got it for the wife to cruise round. What are some first off upgrades needed for the genesis?
      • Mxkid261
        • Jun 2015
        • 734
        Whats the genesis got in it? Stock?
        • Dudleydoright151
          • Jun 2017
          • 9
          Not sure I am guessing stock. I can not get the throttle to work on the genesis. I will snap a few more pics later cause I think the angle of the prop was out cause when putting the boat on the table the boat will sit all the way on the hull flat. I even adjusted it all the way up. Just don't want to get it wet and it leave me stranded since it is used.
          • Dudleydoright151
            • Jun 2017
            • 9
            Is there any members in the oak harbor, WA area?
            • Dudleydoright151
              • Jun 2017
              • 9
              More pictures of what I am working with. Today of cleaning and going over all nuts and bolts found the cable shaft to the prop seems like it has unwound, when you spin the prop it takes like half to one turn by hand to spin the motor is that normal?
              • Dudleydoright151
                • Jun 2017
                • 9
                These show the damage to the hull. What will be a good fix for these?
                • Prodrvr
                  • Jul 2015
                  • 701
                  The motor should turn as you turn the prop...no play. If it's the stock motor, it's a SSS 3674 2075Kv. Good to 6s no problem. Looks like a 160A esc. That one's not stock. That boat came with a Seaking 120A esc. The one you have looks like a Proboat esc. If I were you, I would completely gut it, reinforce it, then build it into a screamer. No comment on the Spartan.
                  • Dudleydoright151
                    • Jun 2017
                    • 9
                    Do I need a new shaft? also how do I know which shaft I need size wise?
                    • Prodrvr
                      • Jul 2015
                      • 701
                      Is there a good part of the flex you can measure at so you can get the diameter? If not, go by the stuff tube diameter.
                      • MG1234
                        • Jul 2015
                        • 638
                        Be sure to tape the hatch of both boats even if you are just cruzing,I still have my first spartan ,it's a money pit but I just can't leave it on the shelf ,the genesis is a great boat ,hull is paper thin ,get ready to inlay some fiberglass ,lots of inexpensive upgrades available to bolt on to make that boat fast and reliable ,both are lots of fun ,
                        • MadProps
                          • Mar 2017
                          • 236
                          your ahead of the game with that used boat.......
                          I just bought one New and it doesnt have any epoxy filling the hole around the tube, water is pouring in the rudder mount bracket bolts, 2 of the 3 motors bullet connectors came apart due to improper soldering, I fixed the leaks but being new to boats I also installed auto bailers after seeing a 1/2 cup of water in the boat after 1/2 a battery pak run , they are a joke they leaked immediately, I adjusted the angle a few times ....still auto sinkers!....these issues on a new hobbyking boat are why I found this site and upgrade parts
                          I am not experienced to give ANY genesis advice so I will parrot what I have read many many times by many many users.....I would not replace that unwound flex tube you found....upgrade to 3/16ths shaft kit like all the experienced Genesis owners have recommended
                          I have purchased upgrade parts for most everything from this site, 40 size leopard, 180A ESC, outura metal prop upgraded cooling line size and dual water pickup rudder & offset.......all I am looking for is a reliable 4s runner, 50mph will suit me fine, the river I live on is too sporty most of the time for a screamer, so 6s will be used sparingly
                          good luck on your repairs and upgrades
