Boat is running with the bow to low = wet running, on that chop it should be flying faster than 32mph. Where is the cg on the boat, needs to be around 30% from the transom not including the overhang at the rear. Also check stinger angle that its not pointing down prop end ( negative angle ).
Leopard 4074 1650 KV
Boat is running with the bow to low = wet running, on that chop it should be flying faster than 32mph. Where is the cg on the boat, needs to be around 30% from the transom not including the overhang at the rear. Also check stinger angle that its not pointing down prop end ( negative angle ).Comment
How about trying a 447.
You will likely see speeds less that what the speed calc gives you due to the size and bulk of the boat. While you are probably using a 25% slip in the calc, the superstructure of your boat will make a fair bit of extra wind resistance over a race hull, this will cause the boat to run slower than you think it should, in effect greater prop slippage. Plus wind and chop will play their part.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
I was thinking the 645 might be an issue as well.NEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6sComment
Prather 225 or 230 may work. I have had good success on my Q mono with them, they run better than octuras on that boat.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
