What kind of epoxy should I use to seal the wood I am using to reinforce the transom?
Using expoxy to seal wood in boats
Tags: None
Where would you find the devcon? Like at auto stores, walmart? Would you have to thin it out? And when you seal it I assume to put the expoxy all over the ply? Also where do I find that carbon looking stuff that I have seen on the exterior of transoms as well?
KenComment
I stopped by my LHS to pick some epoxy up and the guy there said he thins it out with denatured alcohol. I am not sure if this is right.Comment
I usually mix it 30% alchol to epoxy. Don't go over 50%. It will take alot longer for thee epoxy to cure when thinned out. I mix thee epoxy and let it sit for a minute to ativate, then thin it it out, just my method. I use z-poxy finish resign. I like to use it for buildind, when gluing foam or plywood to wood where ca is not ideal.
Jeff
ps: for gluing wood and foam I now use titebond #3. It is waterproof, easy to use and wipe up, no mixing and waste and is lighter than epoxy and doesn't foam and push parts out like urethane glues. Still use z-poxy for laying up carbon or fiberglass cloth.I try and avoid paste eaters.Comment
Just make sure you get the alchaol from a paint store and not the drug store.
The problem with the higher water content is it will cause the epoxy to soften when set. This makes it a mess to try to sand if you are using epoxy as a wood sealer.
Do not use the fast set Devcon.
