$299.99
Efficiently Designed Jet Pump
Self-Righting Hull
Durable Composite Impeller
High Impact Blow Molded ABS Hull
Locking / Sealed Canopy
Solid Drive Shaft
Dynamite 90 AMP ESC 4S Compatible
Dynamite 2300Kv 14-Pole Brushless Outrunner Marine Motor
Spektrum STX2 2Ch 2.4ghz FHSS Radio System
Aluminum/Water Cooled Motor Mount
Stainless Steel Hardware
Realistic Driver Figures
Styrofoam Flotation
Foam Canopy Seal
Boat Stand
Specifications
Type: RTR Deep V Jet Boat
Length: 23 inches (584mm)
Beam: 8 inches (203mm)
Height: 6.5 inches
Hull Type: Deep V Jet Boat
Hull Construction: ABS
Weight: 3.15 Pounds (1.4KG)
Drive System: Jet Propulsion
ESC: 90A ESC 3-4s
Radio: STX2 2Ch 2.4GHz FHSS
Motor: 2300Kv 14-Pole Brushless Outrunner Marine Motor, 33mmx42mm
Battery is NOT included EFLB32003s30 or EFLB32004s30 recommended
Self-Righting Hull
Solid Drive Shaft
Styrofoam Flotation
Foam Canopy Seal
Boat Stand
Specifications
Height: 6.5 inches
ESC: 90A ESC 3-4s
