Transom doublers
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Transom doublers
    On a DF 34 hydro, they come with a white colored doubler of some kind of material. I got some carbon plate from OSE to cut doublers out of for the transom and sponson transom.
    Are the stock doublers strong enough, or should I use the carbon plate I have on top of it?
    • 7673
    Larry, I always double it up. Just to be sure, I would hate to tear a transom off due to a stick.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      I'm thinking I'll go ahead and do it. Thanks.
      I just got started on the build tonight. All I have is my phone for posting pics. Not sure if I'm able to post pics using it.
      Guess I'll find out. Wouldn't mind doing a build thread. Doesn't seem to be many build threads of this boat.
      It either isn't that great of a hull, or people just aren't doing threads on it. Figure I'll see if I can do it with my phone and add another thread for a DF 34 hydro.
      • MarkF
        dinogylipos.com
        • Mar 2008
        • 979
        I prefer wood for doublers so I can use blind nuts. Last time I saw someone rip out a transom was back when we ran plastic or ABS boats.
        Mark
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          Thank you Mark. Good idea with the blind nuts.
            • 7673
            Mmm, yes. Would make assembly easier.
            • Mxkid261
              • Jun 2015
              • 734
              I love the vortex hull I put together a 24 instead of the 34, I like the smaller size. I use aluminum stock for doublers and tap threads in it for the hardware
              • Mxkid261
                • Jun 2015
                • 734
                I love the vortex hull I put together a 24 instead of the 34. I use aluminum stock for doublers and tap threads in it for the hardware. I also added a doubler behind the turn fin bracket. The right side sponson has the swiss cheese looking fiberglass glass mat like the transom does, but I still put a little support behind it.
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3278
                  Thanks guys. I'll use the CF plate that I have on hand. Should work just fine, along with lock nuts and flat washers.
                  • Mxkid261
                    • Jun 2015
                    • 734
                    CF plate will look cooler too
                    • MarkF
                      dinogylipos.com
                      • Mar 2008
                      • 979
                      And a big pain to get to those nuts and washers.
                      Mark
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        I agree, Mark, but I can handle it. (Thumbs up)
                        Although, the transom doubler isn't far from the rear of the hatch opening on this one, so it won't be too bad.
                        • T.S.Davis
                          • 6220
                          Instead of nuts and washers I make aluminum plates for each piece of hardware that I tap and use Vibratite on the screws. The first time I put the plates in place I attached them to the doubler with marine goop. Then I never have to get my fingers down in there to get a nut started again. Ugh. Hate that part.
                          Noisy person
                          • ray schrauwen
                            • 9471
                            You drill and tap after right? Would be a pain the other way. This is what I'm going to do from now on specially for turn fins.
                            There is so little room in a df33 for turn fin nuts.
                            Nortavlag Bulc
                            • ray schrauwen
                              • 9471
                              Mark
                              I used blind nuts for a long time. Even though most of my boats run dry, water always finds a way in like when the hatch comes off etc. Blind nuts tend to corrode over time and wood gets rot. You can use stainless blind nuts to make it less prone to corrosion.
                              Nortavlag Bulc
