Cleaning out stuffing tubes ?
  • zooma
    Local club FE racer
    • May 2014
    • 652
    Well, I thought I had been doing this just right. I have been using pipe cleaners that are dampened with denatured alcohol. Then I re-grease with ProBoat grease in a tube. Today I was doing some post-race maintenance and, when I pulled a couple of shafts, they were gunked up with grease and lint from the pipe cleaners. Also, wads of lint collected where the stinger meets the stuffing tube. (TFL stingers with Teflon liners on Pursuit boats). I have been using craft-store pipe cleaners because the smoke-shop variety are too short.
    Does anybody have a better method?
    Ron - The Villages, FL
  • fweasel
    master of some
    • Jul 2016
    • 4287
    Personally, I use the cheap dollar store pipe cleaners with no alcohol or cleaner. I pull them through my fingers a few times beforehand to remove any loose fibers, and bend about half the length into a kinked shape. I thread them in from the motor side, and out the back of the boat. When the first bits makes its way through the strut, I bend a crank handle shape into it and spin in in circles as I pull the remaining kinked length through the rest of the tube. Occasionally I see a stray fiber or two on a flexshaft the next time out, but never anything worrisome. Sounds like maybe you need to pick a new supplier if you're getting that kind of lint build-up.
    Vac-U-Tug Jr (13mph)
      I almost never cleaned out my stuffing tubes, and they remain clean. I do use gear oil instead of grease, and no Teflon liner. The few times I do clean out the tubes, I use a wad of twisted paper towel pushed through with the flex cable. Works great and done right leaves no residue.
      • Nevs
        Sven
        • Sep 2011
        • 164
        I have never cleaned a stuffing. There is no reason when I use Liqui Moly...
        • Keagan-Z06
          • Mar 2016
          • 970
          WD40, cloth over the mouth of the tube on the inside, spray from the outside and let drain into rag.
          • Nevs
            Sven
            • Sep 2011
            • 164
            If you experience small amounts of water comming trough your drive, ( short strut). Liqui Mole is great. "No" friction..But good sealing.
            • ray schrauwen
              • 9472
              me too
              Nortavlag Bulc
              • zooma
                Local club FE racer
                • May 2014
                • 652
                Do you apply the gear oil to the whole shaft, or just the solid part that rides in the bushing?
                • zooma
                  Local club FE racer
                  • May 2014
                  • 652
                  What grade of Liqui Moly? Seems to come in a bazillion varieties.
                  • Nevs
                    Sven
                    • Sep 2011
                    • 164
                    • zooma
                      Local club FE racer
                      • May 2014
                      • 652
                      Can't find it in USA. Any chance that this is a good substitute?
                      https://www.amazon.com/Liqui-Moly-20...+marine+grease
                      • dasboata
                        • Dec 2010
                        • 3152
                        just blow some carb or brake cleaned threw the tube !!!
                        • rdcracer
                          • Jan 2014
                          • 306
                          I found this but cant find where to buy. I am contacting Liqui Moly to see if they can list distributors. I tried the local marine stores in Tampa with no luck. https://www.liqui-moly.eu/liquimoly/...3Fopendocument
                          Blackjack 29. Deltaforce 33. Cheetah twin, Insane FE30
                          1/10 1970 PaynPak, Aeromarine Jersey Skiff
                          • rdcracer
                            • Jan 2014
                            • 306
                            I contacted Liqui Molly and someone named Scott responded and will let me know where to get the marine grease in the US next week. I will post what he sends.
                            • zooma
                              Local club FE racer
                              • May 2014
                              • 652
                              great
