In theory should be pretty close
electric rigger.
electric rigger
Fitting everything into the tub will likely be the biggest challenge. Suggest 10S2P with a minimum 7000 mAh total and minimum 60C. The TP 5670 if you insist, Kv 850 is probably best. This Kv powers monos and cats in our club into the 70s with a Castle 2028, should be faster in a rigger with more aggressive props. This is an oval boat, not a SAW racer, you don't want or need extreme rpm.
I suspect that that at least some gas riggers and sport hydros (very similar in speed and handling) run in the 80s based on what I have seen at the Gas Worlds. My 4S rigger cuts 12 second laps and tops out in the high 70s on the oval. But FE boats have a very large advantage over gas - instant torque and acceleration. By the time a gas boat is half way down the straight the FE is starting th
.Comment
The 5860 is rated more watts so is stronger motor.
Ray I am running an old Schulze controller. But I have a sworfish 300 that works but does limit rpm some. If I were to buy a new one I would get one of the flier controllers from Chris Fine.
The airplane guys are starting to use the flier esc up to 18s without problem so far, so we think they've worked out the bugs for HV. So for 10s or lower I think they should work fine. But i don't have direct knowledge if they will work good or not. My Castle 160 went up in flames yesterday so I won't be using any of those for 10s set ups. They seem to work good on my 4s stuff.
I am waiting to get the props I need for my set up and will post video when I do. For now I will say I'm running close to 70 mph. Waiting for ABC 2714 and 2814 3 blade choppers.
MarkComment
I suspect that that at least some gas riggers and sport hydros (very similar in speed and handling) run in the 80s based on what I have seen at the Gas Worlds. My 4S rigger cuts 12 second laps and tops out in the high 70s on the oval. But FE boats have a very large advantage over gas - instant torque and acceleration. By the time a gas boat is half way down the straight the FE is starting the next turn.
.Comment
