4mm Flex Drive with 4mm Drive Shaft
  • SweetAccord
    Speed Passion
    • Oct 2007
    • 1302
    Can anyone advise who has these in the states that I may order some?
    4mm Welded Flex Cable: 4mm flex cable with 4mm Stainless Steel ground shaft. Approximately 15 inches long (370mm). Has a 4mm standard thread. $22.00 This is from Kintec's site. http://kintecracing.com/Flex_Cables.html I emailed them asking about availability and no reply and it's been over a week. Everyone must have died over there or something. I can't wait for them, lame.
    Kintec Racing is the only place I find them. I know proboat uses 4mm diameter cables, but I can't figure out which if any are usable for what I am looking for? Any suggestions please?
    Thank you.
  • ray schrauwen
    • 9471
    Most of Kintec racing products come from China. Try an eBay search.
    Nortavlag Bulc
    • properchopper
      • 6968
      Thank you.
      Generally speaking, If Jan has an item in stock it will have a price attached. When you see an item with no priceaccompanying it, it's not in stock. The part you're interested in does show a listed price. Just order it
      • SweetAccord
        Speed Passion
        • Oct 2007
        • 1302
        http://www.ebay.com/itm/4mm-flexible...UAAOSw-nZTn-I-
        I was looking for someone in the states? Ebay has too many fraud issues and the vendors are overseas also. Anyone else that is not Ebay and IN the USA?
        • SweetAccord
          Speed Passion
          • Oct 2007
          • 1302
          Actually backwards. If it has a price and you add it to card then check out, it says it's out of stock. I already tried that.
          Your item(s) sold out
          We're sorry, the following item(s) isn't available at this time:
          • KR 4mm Upgrade Shaft
          • properchopper
            • 6968
            I stand corrected. You might find it here (and they're in Simi Valley):
            Give them a call : 805-387-0600
            • properchopper
              • 6968
              FWIW I know several people who have dealt with Dymotorshop
              {http://www.ebay.com/itm/4mm-flexible...UAAOSw-nZTn-I-
              (and bought high ticket stuff with no problems.)
              • SweetAccord
                Speed Passion
                • Oct 2007
                • 1302
                Ok, Thank you, Thank you, Thank you!
                • SweetAccord
                  Speed Passion
                  • Oct 2007
                  • 1302
                  It appears 4mm flex is too complicated to get readily available. I will just do .150" to 4mm drive shaft. Jeff is making them for me. Thanks for the help. P.S. Kintec never replied still and that was last week. They must have all jumped out the window over there.
                  • jwohlt
                    • Nov 2015
                    • 41
                    Yes...hard to find. The reason is some try and bore the stub out and then reduce the cable to slip in but that leaves the wall so thin that they will break. There is another way. I will get you something going. Almost forgot about it. Darn busy with wire drives and cables for Zelos, Voracity
