Hi forum members,
I burned up 2 esc's recently because of overheating problems. Default settings don't work for all motors/esc's. Should I set my esc's to 0 degrees, run the boat and then take heat readings. If they are low then should I go up 2-4 degrees and continue my heat readings? Let me give you a specific set up and get some advice from you senior members. I have 29" hydro. I'm using a Leopard X2 3660 motor...3180kv....4.5D. The ESC is a 180A version 3. I use a 3/16 flex drive, an Octura 442 prop and I run either 1 3s or 4s lipo..5000mah. Where should I be on my timing for this set up?
thanks,
don
thanks,
don
