I had a setup with a square end flex shaft that fit into a drive shaft within the stinger. I converted it to a flex shaft only (3/8") so I can use different props and loose the drive shaft. Now with the larger props, my esc quickly goes into safe mode when I run full throttle.
I have a SeaKing 180A esc and motor is a Leopard 4092 Motor winds/rpm: - 1730Kv 3D Battery is 6s The new prop I want to run is a Dasboata "1816 BS BC"
Its double cooled and nothing gets hot. I assume the motor is overloaded now.
I cant put my old props (with smaller hubs) on the new shaft because its too thick and also too long.
I figure I could swap the motor out so it can handle the large props and even have more run time in doing so.
What motor should I use? I'd like a high quality one. Thank you.
e
e
