TFL Ariane 2
  • Edwin David
    • May 2016
    • 16
    TFL Ariane 2
    Im an owner of an Ariane 2 and would like to get some inputs regarding CG. I have been using the suggested battery placement of the boat and I have noticed
    the difficulty of the boat getting into plane. Right now I'm using a T180A , Leopard 4092 1390kv motor and 6s 60c 5000 lipo. Can anyone here help me or give me
    some suggestions on my problem? I was hoping I could make it run like the Pursuit,
  • SD Eracer
    • Aug 2014
    • 262
    That's a pretty low KV motor, I'm assuming your are running a pretty big prop?
    My buddy is running an Ariane 2, he has the battery in the stock position, running a T180a, SSS 4082 2000kv on 6S with 5000 heavy duty 60/120C batteries.
    It's really well balanced, running on 42mm prop primarily, runs about 65 mph or so.
    • martin
      • 2887
      CG starting point needs to be around 30% in from transom, is the stinger & trim tabs angles neutral to the hull bottom (stinger not negative). Is their any hook in the hull bottom which will hold the boat down.
      • 785boats
        Wet Track Racing
        • Nov 2008
        • 3169
        The GOG on mine is 10-3/4" from the transom, if that's any help. It wins a race now & then.
