Motor timing
  • slider46
    • Mar 2016
    • 75
    Motor timing
    I just upgraded my genesis with a new SSS 4082 2000kv motor, I have a 180 Seaking ESC and a 445 prop. I will be running it on 6S batteries so I want to make sure the timing is right for this setup. I am new to electric boats and trying to learn this information, What is the correct timing for this motor? I'm not sure of the winding style either
    Thanks,
    Tom
    That is a Delta wind motor, so low timing, 0-5*.
    • slider46
      • Mar 2016
      • 75
      Thanks for the quick reply I will go check the timing before I fry everything...
      • slider46
        • Mar 2016
        • 75
        Would 7.5 timing work ? I have o.oo, 3.50 then 7.50 on up with timing settings...
          Use zero. The 7.5 setting will give more heat, not more power.
          • slider46
            • Mar 2016
            • 75
            All setup and going to run the boat in the morning and see what she does...
            Thanks for your help,
            Tom
            • slider46
              • Mar 2016
              • 75
              I got to the pond this morning to run my genesis with the new 4082 motor on 6s and 0* timing, I was very happy with the results with a 67.2 MPH on its first run...The temps were very low on the esc and motor I would say around 100 as I didn't bring my temp sensor...
              Thanks again for the help,
              Tom
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                That is nice to see.... a person who listened to the advise and reasons...followed them... was happy with results and said thank you.
                Douggie
                • ray schrauwen
                  • 9471
                  Cool and refreshing!
                  Nortavlag Bulc
                  • slider46
                    • Mar 2016
                    • 75
                    here is a quick update on this awesome setup.. I got 2 more runs in today with the genesis on 6s, I played with the balance of the boat by moving the batteries a little bit. On my first run I hit 70.2 MPH and the runtime is close to 6 minutes... I ran my gas cat a few times while the motor and ESC had time to cool down, motor 114* ESC 120* ... Put some fresh packs in and got a 72.9 MPH run on her this just keeps getting better... Very impressed with this easy upgrade....
                    • TRUCKPULL
                      • 2969
                      6 Min. is a long run time.
                      Are you running it until it slows down or hits the low voltage cutoff??
                      Larry
                      • slider46
                        • Mar 2016
                        • 75
                        Yes when the power drops off at all I bring it in. I ran for 4 mins on my first run and the packs were at 54% still..
                        • slider46
                          • Mar 2016
                          • 75
                          When I charged the batteries for tomorrow I was down to 19% of the packs... I will be going to 4.5 to 5 minute runs from now on..
                          • slider46
                            • Mar 2016
                            • 75
                            Here is a short video of the Genesis running 72.9 MPH last sunday... it was a real surprise when I opened up the boat... I have since moved the batteries forward a little and the boat is solid on the water and still this fast.https://youtu.be/Lj6vJqKo7SI
                            • runningman
                              • Mar 2016
                              • 103
                              Hi, what timing should I set for the stock motor? ESC is Turnigy 180A, 4S
