What overall length 2.5mm (.098) wire drives would you like to see?
  • RaceMechaniX
    • Sep 2007
    • 2833
    Guys,
    larger 1/8" with 1/4 stub shaft wire drives are catching on in the gas market. These are very high quality assemblies and can me trimmed to length. The gas size drivelines may only be useful for big S and T boats so I have asked for a smaller system suitable for P and Q. This would be a .098 or 2.5mm wire with a 3/16" stub shaft.
    What length from end to end would you like to see:
    1. 12"
    2. 18"
    3. 24"
    4. Longer than 24"
    Tyler
    11
    12" from end to end
    0%
    18" from end to end
    0%
    6
    24" from end to end
    0%
    4
    longer than 24"
    0%
    0
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
  • properchopper
    rcgoatbuild@snotmail.com
    • 6968
    Tyler,
    I voted for18". My experience (as I'm sure will agree with most others) with wire drives (which have many advantages) is that they like to be as straight as possible, e.g. minimum radius bend. That usually means a more forward motor location ; soooo a long"ish" length would be a good starting point for most P class rigs. Trimming to required length will get the correct dimension.
    • T.S.Davis
      • 6220
      Yeah, why not just make them all long and let guys trim them to fit?
      Noisy person
      • RaceMechaniX
        • Sep 2007
        • 2833
        That is the idea Terry, but trying to find out what is desirable and what is wasteful.
        TG
        Tyler Garrard
        • dmitry100
          • Mar 2015
          • 1264
          How about 6mm stub shafts with 2.5mm precision/polished wire like the one from MBP :)
          With at least 12 inches or so of wire that can be trimmed to fit.
          That way you can use the 2.5mm MBP wire clutches.
          Tyler, can you post any pics of wire setups that you have :) Theres seriously very very little data out there on how a correct wire setup should be like... especially for twin drive cats.
          • T.S.Davis
            • 6220
            I've never seen a 6mm prop. Is that common somewhere?
            The stubs from Octura could have worked but they refuse to drill all the way through the stub shaft. Renders them completely useless.
            I would probably buy a 24 and trim to fit myself Tyler. I do this with flex. Buy long and keep them in my pile of stuff. Then it fits what ever boat I injure or build. Like boom tubes.
            Noisy person
            • RaceMechaniX
              • Sep 2007
              • 2833
              Very few people probably use 6mm stub shafts. And if they are available from Jeff, no need to make them here.
              I searched on MBP and could not find any clutches to speak of.
              These are not mine, I am trying to get Brent interested in making the gas size wire drives in smaller sizes for us. See link here: http://jrcbd.com/forum/showthread.ph...lid+flex+drive
              Unless you have a very very shallow bend, it is not going to work for twin cats.
              TG
              Tyler Garrard
              • T.S.Davis
                • 6220
                .098 has very little bend to it. You wont twist them off but much bending isn't gonna happen. Maybe with the motors up front a cat might work. I run .062 in some of my species but with just a sleeve bearing.
                I ran .098 my first Q sport. Very low resistance. I broke the ball bearings in the strut which in turn mangled the shaft. At the northern nats no less. Ugh. Typical. Also tried it in an 1/8 scale. Built both the same winter. Failed too. Ball bearings were the real culprit.
                I'm older and wiser now. Might be worth another go.
                Tyler, are they using sleeve bearings on the 1/4" drives?
                Noisy person
                • RaceMechaniX
                  • Sep 2007
                  • 2833
                  Terry,
                  I believe he was using ball bearings at first, but they need to be replaced very often.
                  He now supplies them with bushings and that is what I would recommend.
                  TG
                  Tyler Garrard
                  • T.S.Davis
                    • 6220
                    Makes sense. When the ball bearings go it's an epic disaster.
                    I gave up on bearings in my small stuff too. They work fantastic but if you run a lot of laps you'll be buying a lot of bearings. There's never any warning either.
                    Cluttering up your thread. Sorry Tyler.
                    Have you installed one any of your boats yet? I ended up with a motor position quite far forward on the Q boat to get the bend. Then mounted the batteries on each side of shaft. Worked pretty well.
                    Noisy person
                    • T.S.Davis
                      • 6220
                      If these are for bigger boats couldn't he just make a stepped shaft for FE?
                      Noisy person
                      • dmitry100
                        • Mar 2015
                        • 1264
                        Tyler, mind I send you a few pic(s) of the kind of bend and drive line I'm planning to do on my cat build?
                        3/16 - 6mm - 0.098 wire is what my shafts are like (Custom Made by Jeff Wolt).
                        There's about 11 inches or so of wire to play with and it bends quite easily. The motor are being mounted super close to the sponson as well... so the bend seems like it's barely there.
                        I always thought a small bend was actually a good thing with wire? I guess thats wrong...
                        I just don't want mores too far up in the hull as it will be a pain when I'm mounting lipos... which I might just charge from within the hull lol (btw, long wires on cellpro charger = bad idea?).
                        • dmitry100
                          • Mar 2015
                          • 1264
                          Why don't you guys just get Jeff to make whatever you guys want anyways?
                          He supplies OSE with all their shaft/wire combo products...
                          • RaceMechaniX
                            • Sep 2007
                            • 2833
                            Dmitry, I assumed your cat had the fairly aggressive motor angle like most cats I see. If you have a straight shot or slight bend you are OK. The slight bend is preferred as it reduces whipping, so do spacers in the stuffing tube to dampen the nodes and anti-nodes that try to form. PM me the pics of your cat.
                            Jeff Wholt makes nice hardware, but I don't believe he can make wire drives longer than 12". I believe he is using Octura stubs which are good, but not the best for all applications especially where you want more distance between the bushings/bearings in the strut.
                            My interest is mostly for riggers and very high speed set-ups where cable does not like to run. However, wire drives are very reliable when set-up correctly and if you build a boat knowing you will be using one the results are better.
                            I have a 3mm wire drive with 3/16" stub in my Q mono powered by a 2280. no issues. I also had a 5mm wire with 1/4 stub in a DF sniper powered by a 3080. Only issue was trying to get enough clamping force on the coupler.
                            A .125" wire with 3/16" stub would work well for a number of FE boats, but only ones where the motor was very far forward or there was very little bend. Hence I am looking at .098" where I can have more bend in the driveline.
                            Tyler Garrard
                            • dmitry100
                              • Mar 2015
                              • 1264
                              He used quality 6mm stainless steel supplied by a good supply company... I'll try to find the brand he's using. But it's quite good I believe... and I'm sure he can make a custom non-octura stub for you if you asked. I just received another batch of wire shafts last night and they looked even better than before-- very true running.
                              Which spacers do you mean? Like a 2.5mm ID piece of PTFE tube that is mounted after the exit of stuffing tube to keep it waterproof ?
                              I made one that is held on by silicone tubing... was thinking to use something more stronger like a piece of carbon fiber epoxied with that onto the hull attached to the spacer that the wire would pass through but figured the flexible silicone tubing would absorb vibration better.
                              Here's the MBP wire clutches I was mentioning about-- this is a 2.5mm one but they also carry 1.5 and 2mm:
                              I'm using their 2mm clutch drilled for 098 wire by Jeff.
