Recoil 26
  • vincea
    • Sep 2015
    • 91
    Recoil 26
    Ran great for days...
    Now I throw out and runs for a bit than shuts down..
    Sometimes will run again for a long time sometimes shuts down again and again..
    Please help.
    Thx
    Sent from my SM-G920V using Tapatalk
  • truckone176
    • Jul 2016
    • 6
    Same with mine, except I only got about 2 minutes total of run time out of mine and trying to get some help.
    • vincea
      • Sep 2015
      • 91
      Someone said it's the reciver.
      I will call pro boat tomorrow
      • truckone176
        • Jul 2016
        • 6
        That would be awesome as my son and I are getting into the hobby as I used to be into it years ago and he is showing interest and eventually like to build one ourselves.
          • 8011
          The OP failed to mention that his boat fills with water, then quits. No wonder he has problems, water and electronics don't play well together.
          • vincea
            • Sep 2015
            • 91
            I pretreatment my eletronics.
            But true.
            Eletronics and water don't mix..
            • truckone176
              • Jul 2016
              • 6
              I understand that water and electronics do not mix but what do you mean pretreat the electronics?
              • truckone176
                • Jul 2016
                • 6
                I took my boat to my local hobby shop and it was the receiver that was bad. Also, the water issue was due to not enough grease on the flex shaft but my water issue was not severe enough to cause the electrical issues. Thanks for the suggestions and inputs that I received though.
                • dtacmed
                  • Mar 2008
                  • 199
                  Get some corrosion X You can spray all your electronics let it soak in and then wipe off excess. I treat my boat and Plane electronics. Never had a water related failure.
                  • dtacmed
                    • Mar 2008
                    • 199
                    Suggestions versus rude comments may be more helpful
                    • vincea
                      • Sep 2015
                      • 91
                      I contacted Horizon Hobby and they are sending me some new parts to fix the problems
                      • dethow
                        Wired Racing
                        • Oct 2014
                        • 1500
                        Do you know what parts they are sending?
                        I recently had a problem with mine but just assumed the receiver got wet. I'd be nice to know if I should be talking to them as well.
                        Have fun with that....
                        • Mitch S
                          • Jan 2016
                          • 47
                          ^^ Dethow,
                          Customer service is well aware of the problem. Just tell them that the boat cuts out momentarily, then regains power.
                          Its in the receiver. Well known problem.
                          • dethow
                            Wired Racing
                            • Oct 2014
                            • 1500
                            Okay... that's all I wanted to know.
                            I was already planning on switching out my tx/rx to a different brand all together.
                            Just want to make sure there were not other problems that needed correcting, such as esc.
