Catamaran Flex Drive
  • Norman2
    • Sep 2008
    • 321
    Can anyone tell me how you s-bend the shaft as used in a catamaran without
    kinking it. Thanks
    Norman2
    34" Ekos Cat UL-1 Powered
  • Diegoboy
    • Mar 2007
    • 7244
    Install the shaft (& liner if used)
    bend it in very small amounts with your thumbs
    eyeball it as you go.
    • rockwerks
      • Jul 2008
      • 772
      fill the tube with sugar or salt and tape the ends shut then bend it at will.
      an RC rock crawler lost in a sea of boat parts.........
      • Norman2
        • Sep 2008
        • 321
        Thanks,
        • Spot Me 2
          • Jul 2008
          • 769
          It works the best!!
          MMGMMarine
          RobertsonRacing
          • Diegoboy
            • Mar 2007
            • 7244
            Originally posted by Fluid
            You can spend a lot of time spilling sugar or sand or what-not, or you can just go ahead and bend it with your fingers. I've been doing just that for 20 years and have yet to ruin any tubing. I bent the tubing straight out of the K&S rack - NO ANEALING - even the large diameter stuff for the 1/4" cable in my big cats.
            Go slowly and do not cut the tube to the final length until it is bent. I've bent 3/16" tubing in a 3" diameter circle in under 2 minutes, with witnesses.
            This was posted already by the MASTER
            • Spot Me 2
              • Jul 2008
              • 769
              We're not all fluid!!!!!
              MMGMMarine
              RobertsonRacing
              • Diegoboy
                • Mar 2007
                • 7244
                No, we're not. but when Fluid talks, FE boaters listen!
                • Spot Me 2
                  • Jul 2008
                  • 769
                  I agree
                  MMGMMarine
                  RobertsonRacing
                  • bonewar
                    • Jan 2008
                    • 549
                    The way i went about getting my stuffing tube bends right(twin cat) was to put the motors in the spoonons with the wire,flex in the coupler , then run this through to the stinger. i then put a small piece of paper behind the wire,flex and draw the bend on the paper as it is,Then bend the stuffing tube to match your drawing, this will give you a very nice bend in your stuffing tube , one that has the least amount of binding/friction. I've used this method 3 times now with great success. Bending the tube i do with my fingers, just go at it slowly and you will be fine!
                    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                    • Norman2
                      • Sep 2008
                      • 321
                      Flex Drive Bend
                      Thanks for all your help
