Help with amps
  • MG1234
    • Jul 2015
    • 638
    Help with amps
    Don't know if this is the right spot but,I think I'm pulling to many amps on my twin ,wires and connectors get hot ,motor and ESC are just warm but are water cooled,so let's just asume that I'm pulling to many Amps,41" cat ,12 lbs, 6s ,seaking ,2050 TP ,1816 3 blade props ,so what's the fix? I don't want to slow down ,bigger motors ? Bigger ESC ?ill test the amps when the weather changes ,but this is similar to what my buggies do when I push them to hard ,so how do I keep the same speed lower the amp draw ? Seems to me bigger motor ,would a lower KV and a bigger prop pull the same amps as I have now ? Still learning ,
  • StevenBryant
    • Nov 2012
    • 359
    Simple answer, you need to use bigger and connectors, I had a similar problem until I switched to the castle 8mm connectors on my mono and now they run a lot cooler.
      • 7673
      I have a similar setup as you MG (TP's,Fantasm,similar props). I run 6.5 Castle connectors and no issues. Which connectors are you using now? Is everything in the drivetrain running clean and smooth?
      • MG1234
        • Jul 2015
        • 638
        I'm running 6 mm ,I'll give it a try ,thanks
        • oscarel
          • Dec 2009
          • 2127
          Which wires/connectors are getting hot? Not all connectors are the same..
