36 40 ammo motor in micro drifter?
  • 62 bugzilla
    • Mar 2008
    • 258
    I got a 36 40 3900kv motor from a freind and was going to try it in my micro drifter do you think it will work? Or is it to small? The boat it small and light so I thought it might work ok with a low amp draw.
    SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
  • video200
    • 837
    i dont know about that motor. but i used to run my micro drifter with a motor that looks just like the feiago 380 motors, but this one looks like a 380s. thats a 4400 kv and ran nicely on 7,4v 2200.
    but i am running 25 and 28mm props with around 1,4 pitch.
    im now running a 380L and that is to much on 11.1v and 28mm prop
    • Simon.O.
      • Oct 2007
      • 1521
      Given that I have all of 10 minutes of BL experience I will offer up an opinion.
      A 36-40- will not have a lot of torque
      I now have a 36-36-4000 and it is very close in power to a 23t brushed can.
      If that is the sort of power that it takes to get a MD up and honking then you are on a winner. If not then you will need a longer can.
      I have JUST found all of this out, the hard (my) way.
      • raptor347
        • Jul 2007
        • 1089
        We run those motors in spec riggers at our club races. The hulls are 25" and go like crazy. We are running V935/3 blades and modded 2135's. These run race distances without cooling and get to ~130F.
        The little motor has more power than you might think. Start with an X435. This is assuming you'll run 2S Lpos. Conside a Castle sidewinder for an ESC.
        My .02
        Brian "Snowman" Buaas
        Team Castle Creations
        NAMBA FE Chairman
        • 62 bugzilla
          • Mar 2008
          • 258
          thanx
          Thanx alot for the input. I thought it would go pretty good and yes I am running 2s2p 3600 25c poly rc with a x power 100 both water cooled and will start with a x632 and go up from there. Hope it goes good. I will let you knopw and ad pics after it's installed.
