STS 250 problems
  • grayhamby
    • Mar 2014
    • 38
    STS 250 problems
    Has anyone had a problem with the bearing in the STS 250? Any replacement suggestions? grayhamby
    • 7673
    I blew my bearings on my 3/16" ones. I was definitely using them to hold water out. I found the bearings to be common on RC 10's and Losi cars. Not sure on yours though, just google the bearing size. They pop out easy and should be a common size.
    • grayhamby
      • Mar 2014
      • 38
      STS problems
      Thanks GRH
        I blew the bearing out on every one I used. I replaced the beating with a higher quality one. I stopped using them tho.
        • dmitry100
          • Mar 2015
          • 1264
          You would think for $15 bucks they wouldn't cheapen out by using some $0.50 cent bearings there...
          LOL.
            • 7673
            Well, I just got pack of bearings so I'm going to give it a go again. It may be too much RPM for RC car bearings but I smoked the silicone tubing I was using to keep water out.
            • dmitry100
              • Mar 2015
              • 1264
              Have you tried using heat shrink along with a small diameter teflon spacer or anything like that ?
              Kind of like this: http://mbp-rc.de/bilder/produkte/gross/5408_b4.png
              Teflon would be the only thing that would withstand that kind of high temp in driveline anyway...
                • 7673
                That could be a great idea there Dmitry, or, er, should I say 'Joe'.
                • drwayne
                  • May 2008
                  • 2981
                  Twin hydro .. both my .250 had death rattles after a day's run .. always lubed with auto trans fluid
                  ( drip feed lube header bulb inside .. overkill is my middle name lol )
                  Threw them to the .. 'can.
                  W
