does anyone use the bullet ends that go on the end of the prop or do you just use a nut. just wondering as i have a couple of bullet ends but dont know if there is any advantage useing them or if they put the prop out of balance.
prop nuts or bullets
Tags: None
I have lost 2 new props thanks to the bullet nuts. I don't use them anymore."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
In my experience i have never been able to get the bullets tight enough so they always come off usually resulting in a lost prop..........just my dos centavos!!!* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
thanks for the quick replies. yea like the bling bling factor. was going to put a small split washer on between the prop and bullet to see if that holds on. but i just finished a couple of new props and dont want to loose themComment
A bullet nut could help if you are using totally submerged props. They do not help when using surface piercing props. I use a small lock nut.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
Aeromarine sells their bullets with a nut that goes on first. You tighten the nut on the prop and then tighten the bullet on the nut. They are rock solid.Team Liquid DashComment
