Promarine?
This topic is closed.
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    #46
    The confusion about the TFL SSS motor is a matter of terminology I believe.
    They are a 4 pole motor. That's 4 windings in the stator.
    But the ROTOR has 6 magnets (6 Poles) as opposed to most other motors that have 4 magnets in the rotor.
    It clearly states 6 pole ROTOR on the box.
    They claim an extra 20% torque. So if you are using the same size prop as with an equal sized & KV Leopard motor your temps & battery usage should be less, as is evident by what SD Eracer has stated.
    I've been a fan of the SSS motors for a long time.
    • T.S.Davis
      • 6220
      #47
      It could also be that the SSS motor is labeled 2000kv but is actually putting out a tic less than 2000kv. Kinda like the Aquacraft. 2030 listing but not actually putting that out. If the SSS were even 100kv less that could/would make for a little better torque and less heat. Especially on 6s. Wild speculation on my part though.
      2000kv is too many rpm for 6s but we've been through that a hundred times. We'll never agree on it. It always comes down to GPS guys arguing with heat racers.
      Noisy person
      • keithbradley
        • 3663
        #48
        Are you sure we're taking about the same motor? The motor in question is a 4082 (not the larger 56mm motors that have always been 6 pole).
        www.keithbradleyboats.com
          I think the motor in question is this one
          http://www.offshoreelectrics.com/pro...?prod=sss-4082
          • keithbradley
            • 3663
            #50
            In case I wasn't clear, the question was for Paul. I know we're taking about the 4082 (I stated that in my post). However, I want to be sure Paul is talking about the 4082 as well. If he has one with 6 magnets, that means that SD Eracer's initial thought that there were two different versions of TFL motors is correct.
            Before we go down "didn't you read the write-up" road, the answer is no; I don't consider product write-ups as gospel. An alarming amount of product information is incorrect, even from the manufacturer.
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              #51
              Hi Keith.
              Yep. Definitely talking about the 40 series motors. I've got a few of them now. They all said 6 pole 'Rotor' on the pack. Always seemed to be a stronger motor than the Leopards to me. I haven't pulled one apart to check it but I don't think they would make a false claim on the number of poles in the rotor when it is so easy to check.
              But as you know, a 6 pole rotor does not make it a 6 pole motor. It's the stator windings that determine that.
              • keithbradley
                • 3663
                #52
                Hi Keith.
                If you have one on the shelf pop the end off!
                I'm curious now...it sounds like there are two versions of motors, or at least two versions of boxes.
                I got these motors before they were really as popular as they are now. The boxes they came in were very plain and didn't say much of anything. I have pulled one apart though, and it's 4 pole with 4 magnet strips. That makes sense to me since they told me they were machine-wound copies of TP motors.
                I'm curious if they have since sourced a different motor than what they were originally selling.
                • SD Eracer
                  • Aug 2014
                  • 262
                  #53
                  Hmmm, that could be the case as well. I've read how certain manufacturers will lower the kv than actually stated on the box. Though 785boats explanation of 6 pole rotors makes a lot of sense as well, maybe a bit of both?
                  I agree with you on the 2000kv on 6S for the most part, I prefer higher amps and lower kv, but these SSS motors in our club have been very good, even in non-SAW type applications like large sporting monos. The temps and amp pull have been very impressive, so much so that instead of fitting TP or Leopard on my HPR, I went with the SSS brand, something in the past I wouldn't have considered. Heck, I typically gave away the SSS motors that come stock with my TFL boats because I thought they looked suspect.
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    #54
                    Keith.
                    Seems your suspicions on the packaging is well founded.
                    I just pulled the rotors on a 4082 2000kv motor & a 4092 1650 kv motor, & they are both 4 pole rotors. Needless to say I'm more than a bit disappointed in this.
                    Unfortunately most people advertise them as a 6 pole motor. Even Steve here on OSE. Obviously the tech data comes from TFL.
                    But the way that is written, it means 6 windings in the stator.
                    There are some "Team TFL" people here on this site that get hulls & motors etc from them for testing. Maybe they can get in touch with their contacts & find out the truth.
                    • SD Eracer
                      • Aug 2014
                      • 262
                      #55
                      Now I'm curious. How did you pull the rotors? Besides removing the 4 bolts holding the barrel ends?
                      • ray schrauwen
                        • 9471
                        #56
                        Use a pair of HD pliers with the jaws taped up to prevent marring the shaft. To be more careful I use a piece of lexan about 0.015" or 1/64" just the right size to wrap around the core so when you pull it out and replace the rotor, the coating does not get torn or freyed by the stator plates.
                        Nortavlag Bulc
                        • SD Eracer
                          • Aug 2014
                          • 262
                          #57
                          I actually got it off, looks to have 6 magnets on the rotor.
                          785Boats, how long ago did you buy that 4082, was it from Steven?
                          • JMSCARD
                            • Mar 2010
                            • 3444
                            #58
                            I saw his youtube and remarked... how is he stating you should see it on 6s with a 120 amp speedo? Is he running a 32mm prop lol... there is no way someone should be telling folks to run a boat reliably on a 2075kv supposedly kv anyway motor on 6s, and without question not on a 120a speedy???? 5s... no that's a different story... for the motor anyway... still will need a esc upgrade.
                            I do agree the boat is very sharp... I very much like the more scale appearance, and if it is 6s capapble with that 2075kv motor and the 120a esc.... guess it better be trimmed awful well, I still wouldn't run one with that motor on 6s, seems more appropriate motors for 6s operation that wont wear out your strut bushing after very little running.... just that kind of rpm isn't needed...
                            • 785boats
                              Wet Track Racing
                              • Nov 2008
                              • 3169
                              #59
                              That one was still in the box & I only bought it a month or so ago from R/C Boatbitz here in Oz. They can't be blamed though as it was still in the packaging from TFL which clearly states 6 pole Rotor. I'll send Joe an Email to see if there is anything that can be done with TFL.
                              Good to hear that you have the 6 pole rotor though.
                              • SD Eracer
                                • Aug 2014
                                • 262
                                #60
                                Sorry to hear about that man, but I'm sure Joe will make it right.
                                I'm currently at a ski resort here in Southern California, couldn't miss the first good snow days down here. Luckily though, I brought with me my motors and ESCs to do some soldering during our downtime, and was able to inspect the motors.
                                I kinda was certain they were 6 pole by how much resistance I was feeling rotating the shaft, quite a bit more than my 4-pole Leopards, which I assume is because of the additional magnets.
                                Have you had a chance to inspect those motors you are running? You seemed happy with the SSS motors you have, I wonder how many poles they have. If they are also 4-pole, then there is some other things going on that has made them more "gentle" than the Leopard 4-poles.
