What is the difference in props?
  • eric-paul
    Luke Propwalker
    • Jan 2008
    • 34
    octura 1440; octura x440; octura m440
    are they not the same pitch and diameter?
  • ReddyWatts
    • 1711
    14 are moderatley high lift for hydros and deep V's
    X4 are medium lift general purpose props
    M4 are like X4 but with the tongues removed to unload the prop
    ReddyWatts fleet photo
    • eric-paul
      Luke Propwalker
      • Jan 2008
      • 34
      Thank you for the answer.
      • andym
        More Go Than Show Prop Co
        • 2406
        Hey Blane I think that a 14 series prop on a deep v would not be a great idea. Have run them on my riggers with good results though.
        • ReddyWatts
          • 1711
          I guess a moderatley high lift prop on a deep v can help hold the bow down? Got that from the Octura prop description list.
          Different types of Octura props
          12 are low lift ideal for submerged drive
          Y are like X series but have 10% more pitch
          X5 are general all purpose med lift prop
          X6 are higher lift than X4 and suitable for surface/semi surface use
          16 are high lift props for riggers and hydro's
          17 are the highest lift prop for riggers and outboards
          P7 are similar to 17 series but more rake and less lifti
          19 are high lift for riggers and hydro's
          V9 are moderate lift suitable for riggers, hydros and SAW racing
          20 are moderatley high lift suitable for riggers
          21 are high lift for riggers and hydro's 22 are high lift surface drive only good straight line speed
          • mtgoat
            • Apr 2008
            • 81
            In practical terms, what effect does this have?
            • ReddyWatts
              • 1711
              The tongue is used mostly when taking off and low speed acceleration. Removing the tongue allows the prop to turn easier at high end rpm for a faster top speed.
              • Doug Smock
                Moderator
                • 5272
                This will help, "areas to cut"
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • Ocean Racer
                  • Sep 2007
                  • 502
                  SO the tongue is epual to putting small tires on a car you take off quick but not for long. So from what I got from that is if you mess with the tongue you can get a perfect prop. You can shave a little off and get the right amount of acceleration to fly at the start. Plus you have a small enough tongue that you get a good top end. right
                  Failure is the First step to SUCCESS
                  • andym
                    • 2406
                    Yes,..........................................
                    • Diegoboy
                      • Mar 2007
                      • 7244
                      Wow, pretty good stuff!
