Jet Pump
  • Pau7060
    • Nov 2014
    • 67
    Jet Pump
    Hi Got a question what's biggest motor battery combo that can be run with this type of Jet Pump .XL Jet Pump.jpg
  • TRUCKPULL
    • 2969
    What is the make and model # of the pump?
    With this information you can look for the specs on line.
    Larry
    • Doby
      KANADA RULES!
      • 7280
      Looks like one Hobby King sold (or sells)
      Grand River Marine Modellers
      • Doby
        KANADA RULES!
        • 7280
        http://hobbyking.com/hobbyking/store...e_X_Large.html
        • RunningBeer
          • Aug 2014
          • 90
          Hi, I see that that pump has a 53mm impeller. I'm not sure if this helps but my Swashdrive jet pump is running on 10S, a 480 KV motor and draws about 90 amps for a pretty good run time. The Swashdrive is a 56mm 3 blade impeller over a 7 vane stator and is a 'mixed' flow pump.
          Cheers R.B.
          • Pau7060
            • Nov 2014
            • 67
            Hi too all , I have three more days at work and will be laid off / plant closer after 37yrs in Aircraft World . I will have lot's of time to work with my stock pile of parts and hulls. I have a SeafireTunnel & Hydro / BBY Hydro / and a Insane 30 Hydro / plus the F1 Tunnel with my home made outboard with Zenoah Power. I have bought over the last year and a half . Legg Lake will be home waters , along with very small shallow pond near my house. That I am building a Jet Pump Drive Boat for XL Jet Pump.jpg It's going to be all Alum Eliminator Hydro . And I all most forgot a Beez jet hull and pump.
