I'm looking for a small gps for speed tests. Any suggestions? Thanks; Don
I just looked and the ones that came up under GPS sure not the right one there is a term for them and they look just like the ones you see the guys using on utube ,I think I've asked this question before but it didn't come up on the search bar ,maybe someone will tell us what they are calledComment
I haven't purchased this from HK, but I find the size and powering from the receiver interesting.
http://www.hobbyking.com/hobbyking/s...?strSearch=gpsComment
Dynamite GPS is good... 10hz refresh rate. and it is built on the Holux chip.
It also happens to be very very light... and floats on water (an unintended benefit :))
Gets soaked for a few hours and still works fine.
The only issue is that the software is junk. Only works properly after updating the device with the latest firmware...Comment
I bought the HobbyKing GPS, I wish I had not.
The sample rate is ONE sample per second which is far from fast enough in my 150 foot test pond.
The GPS chip is supposedly capable of TEN samples per second but the included software is not.
HK should source software that does this, otherwise it takes someone who has the skills to reprogram.Comment
I have tested many:Sky is junk,Quanun is ok when you learn to deal with it , Holux 245 is a good small unit if you have enough space in your boat BUT Garmin forerunner is definetiuvely what I would recommend.GillGO FAST AND TURN RIGHT !
www.grsboats.com.brComment
Yea, thats what I do. Strap it down well with waterproof duct tape like Gorilla tape. Just be sure you update the firmware to the newest version otherwise refresh rate won't be 10hz. Even if you set it be 10hz inside of their software. The only way you can update the firmware on the device is by holding down the top Options button when you turn it on... and then right away pressing the update firmware button on their windows software. It'll take a few times of trial and error lol...Comment
