850mm (33.5") Carbon Fiber Mono Deep V Hull setup help
I use west systems for most everything. Jb weld on the motor mounts with a light coating of clear epoxy with black dye in it for a finished look. If I locate something I may want to remove later I use (believe it or not) 5 minute permatex two part epoxy. It's very strong but will let go when I need it to with no damage.Comment
I used slow hardener in Las Vegas in the summer outside. This was at night 95+ degrees and the WS101 set up in about 4 hours. I wouldn't use slow at 70 degrees if I wanted to work on it the next day. Just remember the slower the cure the stronger/tougher the final product.41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.Comment
The K number is the amount of individual carbon fibres in thousands that make up the tows that are woven into the cloth, 1k is a very fine weave with minimal print through that may be used as a top layer for cosmetic reasons or on small parts for its greater flexibility, but is very expensive. Conversely 12k is a very course weave that is cheap to make and good for relatively flat areas where texture is not an issue.
Spread tow fabric is a little different as the tows are spread out thinly into flat strands before being woven, this give the ultimate in lack of print through whatever k, the k determines the size of the squares in the chequerboard effect, flexibility will be very poor for all Ks.Paul Upton-Taylor, Greased Weasel Racing.Comment
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I decided to build this hull perfectly. I brought the hull to a friend of mine which name is Serkan Cigir. He is the leader in my country in rc boat hobby. He decided to put 90/m2 carbon cloth inlay to the hull. I will choose the motor. I havent decided yet. Any recommends very well come. Will post pics soon.Comment
May I have your opinions about the hardware which I bought?collet.jpgfins.jpgstinger.jpgtrims.jpg
Aluminum Stinger for 3/16" Cable Shaft Full Set
5mm un-threaded to 3/16" 4.76mm stainless steel collet coupler
Aluminum Turn Fins 75x32mm
Aluminum trim tabs black anodisedComment
Hi tuncd,
Your CG needs to be around 30-33%. Use your battery position to be the adjustment. The hardware looks good. If you want a better coupler get an MPB one, but that one should be ok.
Are you going to play, race or zoom zoom? This will ultimately affect your motor choice as far as kv goes.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
Hi tuncd,
I will play with it, I will try to race, to be honest I am a little confused, couldnt find the motor, it has to be Leopard.
If you may recommend a motor you are very wellcome.Comment
As Trav has said TP 4050 or 4060. I have both, in my pursuit the 4050 2050kv (4s), and my new Q hydro 4060 1620kv. In the 1400-1600 kv range for what you are doing should be good.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
