Hi,
I am new to the fast boats. I have an 32 years old scale boat, around 11 inch long. It's all electronic was dead. Since it meaned alot to family (lot's of good memories) I repaired and got it much faster. Added navigation lamps and a projector etc. etc. I completed that project. Now it is time for a fast boat!
Now, I am upgrading NTN-600. I got 120A Hobbyking ESC, I will use the original motor, which is 2858kv and use 4s lipo battery. I will add a mini dc pump and again navigation lamps to this boat also. I bought transparent screws and nuts to mount canopy hatch. I will mount a led to each screw, and hope the screw and nuts will pass the light to outside. And I don't trust the water cooling system of NTN-600. I will use a mini pump for it. Both navigation lights and pump is radio controlled (I have 6ch receiver).
The thing I don't know is, which battery should I use? I am looking 4s batteries between 4000mah - 5200mah. I found Multistar 5200mah 10C battery; but I have some doubts about it, since it has a 10C discharge rate. But it has light weight. So I could not decide. I guess my burst consumption would be more that 52A. So, I guess this battery is not for me. If you say it won't be a problem, I'll buy this battery. If it is a problem, I will look at least 20c batteries...
