Cracked carbon fiber hull
  • MG1234
    • Jul 2015
    • 638
    Well shoot ,bumped a cement wall a little hard with my Zonda and it cracked across the top of the sponson ,it is an off set crack,can I clean it up and use JB weld ? Or do I need to order that west product resin for carbon fiber repair? Same approach as fiberglass repair? Other than that what a great day at the lake ,smooth water and fast boats ,
  • SD Eracer
    • Aug 2014
    • 262
    Do you have a pick of the crack?
    You really should reinforce it from the back side, normally a sheet or two of carbon fiber cloth and resin is an easy yet effective fix, but considering its location, it maybe difficult to reach.
    On new boat builds, I normally would fill the tip with epoxy resin, it makes it almost bullet proof and adds a nice amount of weight to the front of the hull. Then brush a light amount of thin epoxy or resin on the exterior crack itself. Then I hide the crack with a nice decal or something like that.
    • MG1234
      • Jul 2015
      • 638
      I did the resin fill on my genesis and it did make it stronger but now I can't get the nose up,on my Zonda the crack runs across the top of the sponson straight in line with the front of the hull then down the inside of the sponson ,it also opened the seam across the front ,I cleaned it out with a dremmel and put black epoxy in the crack ,can't get to the inside,I have a body shop guy that says he can fix it I just need to buy the repair kit on eBay ,2 more weeks and it will be desert season anyway ,
      • SD Eracer
        • Aug 2014
        • 262
        How much resin did you put into the nose of your Genesis? I have two Genesis boats with epoxy filled sponson tips, filled with expanding foam which makes them even heavier in the front, but I still have to use an airdam to keep them from flipping over.
        That's cool about the body shop guy, what kind of repair kit did he want you to purchase?
        • MG1234
          • Jul 2015
          • 638
          There is a Carbon fiber repair kit ,like a 2'x2' mesh and resin,to do small repairs ,on my genesis it has a 4092 1750 kv ,I milled the strut to get a little higher,have a M447 and x648,I have the batteries back to the water out let,and it still runs wet ,it used to blow over and I had a wind damm on it ,but after multiple sponson repairs it won't get up on its tail ,I'm going to try a little weight in the back tomorrow ,
          • SD Eracer
            • Aug 2014
            • 262
            Wow, our setups are pretty close. I run a Leopard 4092 1730kv with a M445 & M447. On that hull, after getting a few stress cracks after some 60 mph flips, I reinforced it with a couple of layers of fiberglass cloth and resin. Quick and dirty like, just laid and resined around the motor mounts and trays, didn't remove anything. Been bullet proof ever since, including some crazy 70 mph flying barrel rolls. My newest hull has been reinforced with 12K carbon fiber sheet, should handle 90 mph flips.
            I guess its just too much weight in the front of your boat. I've seen someone put a spoiler wing the back of their SAW cat to help with the front, maybe an idea instead of adding ballast to the rear.
            • MG1234
              • Jul 2015
              • 638
              At our local lake there is a cement curb that holds the shore in place,that thing is my enemy,some hits were my fault ,others were just bad luck ,but all my damage to both boats is that curb ,the water is about 2' deep and you need to stand in the water to see because of tall vegetation ,I can get a hull already re enforced for 89$ ,might buy one this winter and swap stuff over unless I find a better hull ,just bought a used HOR racing 41" cat ,put twin 1800 kv ,came with shafts and huge props ,it has been so re enforced it's heavy ,gonna run it for the first time tomorrow ,6s each motor,
              • dmitry100
                • Mar 2015
                • 1264
                You're probably better off with either fiberglass or CF mesh along with some epoxy balloons + epoxy and filling up that sponson... check my thread about it if you want
                • MG1234
                  • Jul 2015
                  • 638
                  How do I check your thread ?
                  • z400
                    • 1311
                    You click this link and read through the provided information.
                    http://forums.offshoreelectrics.com/...-it&highlight=
                    Do you wreck all of your boats?
                    Z
                    KBB34" Mono - Fast
                    ToySport Triton- Not as fast
                    • MG1234
                      • Jul 2015
                      • 638
                      Yes ,just started this summer on boats ,Spartan ,then genesis ,then Zonda ,now HOR racing twin,buy hey my kids are grown and I can buy a fast RC boat for what it cost to go skiing one day ,
                      • dmitry100
                        • Mar 2015
                        • 1264
                        • MG1234
                          • Jul 2015
                          • 638
                          I read that but I still don't understand epoxy balloons ,what or how they work ,thanks
                          • dmitry100
                            • Mar 2015
                            • 1264
                            It's just used as a filler to keep the weight down ... Scroll down to "Micro balloons" http://kintecracing.com/Building_Supplies.html and I'm sure you can find similar stuff on places like amazon with free shipping etc.
                            Is your damage similar to mine ?
                            • MG1234
                              • Jul 2015
                              • 638
                              So micro balloons are not balloons at all it's just an adative,I had some idea that they were balloons you insert in hard to reach places ,like the tips of a sponson ,that would help shape the repair ,then once the glass is done you remove them ,so energy of my ignorance ,if I fill the sponsons all the way to the crack which is at the front of the boat ,what's the lightest stuff to use ? I've read so many ideas ,there's that expandable stuff ,or the micro balloon adaptive ,help please
