Outboard alignment help plez
  • riversidedan
    • Aug 2015
    • 103
    had this hull sitting around and got a HK formula 3 OB and need someone to tell me how to align the motor to the boat, or where does the driveshaft line up with the stern?? thanx
  • oscarel
    • Dec 2009
    • 2127
    Set it on the table and put center of prop even with bottom of sponson and adjust from there.
    • riversidedan
      • Aug 2015
      • 103
      ok thanx but had to raise the hull up cuzz it wouldn't sit flat on table, other than that the prop ctr is lined up with the sponson, is that what ya mean?
      • oscarel
        • Dec 2009
        • 2127
        Hard to tell, but looks close.
        • riversidedan
          • Aug 2015
          • 103
          ok will try to get another shot today so plez check back or look at below pic
          • riversidedan
            • Aug 2015
            • 103
            the sponson has 2 points which one should the prop shaft line up with A or B ?
            • dan pralle
              • Sep 2013
              • 141
              B.
              • trigger
                • Sep 2013
                • 853
                probably pulling the aquacraft Top speed 3 instructions from the aquacraft web site will give you all the starting points you need. hope that helps.
                • riversidedan
                  • Aug 2015
                  • 103
                  any info I can get will be helpful, thanx
                  • trigger
                    • Sep 2013
                    • 853
                    • riversidedan
                      • Aug 2015
                      • 103
                      didn't really get too much about motor install so will just have to trial and error
                      • oscarel
                        • Dec 2009
                        • 2127
                        I can post a picture of mine later tonight, but yes B. Again, set it on a flat surface and the prop shaft should line up with the bottom of the hull where it makes contact with the flat surface. It doesn't have to be exact as you'll need to make adjustments once you run it. Why wouldn't the boat sit flat?
                        • oscarel
                          • Dec 2009
                          • 2127
                          If you look on page 18 they have the boat sitting on a setup board and the prop shaft is sitting just on top of it through a cutout. This is what you want. The middle picture you can see the hull and the back side of the lower unit. There's also good advice on page 21 and 22.
                          • riversidedan
                            • Aug 2015
                            • 103
                            the boat will sit flat on a table however was getting confused about "how the hek can ya sit the boat flat and fit the motor with the bottom of the keel hitting the table LOL "brain fart" but yes I can now sit it flat with the stern hanging off the table edge and hold the motor up so when ready to mount the prop shaft will lineup with B and yes shoot me a pic of yours when ya can thanx
                            • oscarel
                              • Dec 2009
                              • 2127
                              Here you go, it's got a lot of negative because the last race was very rough.
