.78 wire drive
  • andym
    More Go Than Show Prop Co
    • 2406
    .78 wire drive
    Just out of curiosity how much power can a .078 wire drive take. Am thinking of running one in my Delta Force 33 with a 1521 series Nue x446/3 prop. The angle is very gentle as the motor is very low in the hull and it is only approx 4" from coupler to prop shaft.
  • Simon.O.
    • Oct 2007
    • 1521
    Andy, I have just had a good read about wires (again) and it seems that .078 wire will be fine.
    Jeff should be along soon to give you a more informed opinion.
    I love my wires.
    • RayR
      @SiestaKey.calm
      • Jun 2007
      • 1518
      Andy,
      I'm runnig my DF33 with a 1515/1Y and a X640 on a .062 wire. Works great, Now, would it hold up to that big monster prop? 0.78 should work just fine!
      Ray
      • Ub Hauled
        • Aug 2007
        • 3031
        I think Joerg used a .98 wire on his T rigger... I think it can handle a lot of power.
        Corrected as per J.T.
        • andym
          • 2406
          Thank you all very much, will be giving it a go as soon as Steve gets the couplers in.
            The problem with using wire is the length is too short. For a 4" length you are better off running .150 cable.
            Joerg used 0.098" wire on his big hydros - or the closest metric equivalent anyway. He also did not use "hobby wire" but a stronger industrial alloy. Engineering model boats is not as simple as copying what you think someone else did....
            • Ub Hauled
              • Aug 2007
              • 3031
              Jay, you're right...
              • RayR
                @SiestaKey.calm
                • Jun 2007
                • 1518
                OOps, missed that 4" length. My motor is mounted forward.
                Ray
                • andym
                  • 2406
                  May I ask why the short length is a problem?
                    Wire, particularly thicker wire, needs a gentle bend to avoid excessive side loads that cause excessive friction. Also a tighter bend stresses the wire and it is more likely to break from fatigue where it enters the stub shaft. Just last Saturday one of our club members broke a 1/16" wire in his LSH, which BTW had a pretty gentle bend. It was run too long and simply fatigued.
                    You may be able to work it - try if you want - but IMO 4" is too short for wire if the bend exceeds ~5 degrees.
                    • Xzessperated
                      • Apr 2008
                      • 3060
                      Andy, from what Jay is saying I think I would be replacing that wire regularly if I went ahead with that idea. I can see he is saying the shorter the wire the harder it is to get a gentle bend in it (please correct me if I am wrong Jay). The problem with metal is that it often does not show any signs of fatigue until it breaks.
                      Several boats in various stages of destruction
                      • Ocean Racer
                        • Sep 2007
                        • 502
                        Unless you are using it in a bridge or something HUGE!!! But ya you prabably wont see the sygns until your prop is flying down the water without a boat.
                        Failure is the First step to SUCCESS
                        • j.m.
                          • Jul 2008
                          • 838
                          that's why you put a wheel collar on the shaft infront of the stuffing tube, but behind the coupler. Just extra insurance.
                          If the coupler comes loose, you still have a wheel collar to hold the wire and prop in the stuffing tube.
                          • Flying Scotsman
                            Fast Electric Adict!
                            • Jun 2007
                            • 5190
                            A great thread. I am more of a sport boater and will on a good day push the envelope. I use mostly .150 and up cable on my setups and have had good results. I have never used a wire setup but I understand the perceived advantages. I just like tried and true drive setups which, I am comfortable with.
                            Douggie
                            • j.m.
                              • Jul 2008
                              • 838
                              Wire drives are tried and true. More true than flex cables, though not tried as much.
