While as a novice fe boater I won't try to guess what the problem is with the op's boat, I had problems with the mhz drives in mystic 114. My issue was too much negative angle which made the boat run too wet.
Iirc Keith offered some modified drive support posts which would have corrected the negative angle, but I liked the look of those original drive support posts so went another route to fix my problem. I made holes in the hull so that the bases of the drive support posts sit flush with the hull. Handling was the same after the fix (I think). I've been using Leo 1600kv motors with 442 props so neutral drive angle is just fine for me.
First image shows the start and last 2 the end result. If you want to read the build thread, its here.
-Titu
-Titu
