Got the Sprint Cat in the water today with a Turnigy Marine 180A ESC replacing the 180 Seaking that I blew up. The boat ran pretty good. A little sluggish until on plane. But once planing, it moved with good speed. About 2X faster than with the Seaking ESC. (It used to be a slug) I think my lack of speed before was due to not getting full throttle. I was using Tactic RX and TX. I have changed to a RadioLink RC3S. which I can cal the ESC at 100% on the TX. Then set the TX to 120%. Read somewhere this is the way to be sure you are getting Max throttle. Although it may be causing an issue. I brought it in for a 1 min run temp check and red led was flashing on ESC. With M445 prop, ESC was 103, motor 105, batts 95, ambient temp 95. Everything running cool. But I cant see water coming from the outlet when running. So I don't think I am getting enough flow for hard running or M545.
My questions are,
1. Any comments on the above?
2. Anyone increasing the size of the water pickup hole in the rudder?
3. I know my rudder is too long. What length rudder works best for Mean Machine/Sprint Cat 29"? I think someone said 3 1/4" below the ride pads. Mine is 4 3/8".
My questions are,
