New item TFL Outdrive and motor assembly.
  • mappo
    • Feb 2010
    • 488
    #46
    Id say something in the 30" area.
    a 55" would need the arrow shark gas outdrives with an electric motor.
    Would these drives be able to handle bigger motors?
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
    • Tanner Basch
      • Jul 2015
      • 5
      #47
      What about a 46inch hull
        • 7673
        #48
        It says 42mm prop max. My twin AC Lazer 40 goes real good with the 442's(48mph). Other than that I think it would be a personal take on the scale look and size for a hull. I agree with Darin, one should grab a couple then pick out the hull. Maybe that 36" fountain P1.
        • ls1fst98
          • 859
          #49
          It looks like a quick mod with a dremel you could accommodate a larger prop. Doesn't appear to need much to clear. I'm also wondering about the durability if you would put a 36 or 40mm can on these.
          • Tanner Basch
            • Jul 2015
            • 5
            #50
            If i ran 2 of these on a shockwave 36 would you guys recomend a 40mm 3 blade or 2 blade prop
            Thanks
              • 7673
              #51
              Thanks
              A set of three blades would be smoother on the drivetrain.
              • Tanner Basch
                • Jul 2015
                • 5
                #52
                Sorry guys for all the questions im kinda new to this. I kinda want a scale look not really speed, but will a set of 4 blades be to much?
                • gb tiggycat
                  • 70
                  #53
                  Originally posted by cybercrxt
                  Definitely Darin, I plan on giving the company feedback once I look inside them more. I want this company to have the info they need to make these units easy for their customers to use and maintain. I was already told by good friend/ boat mechanic that purchased two of these, that the grease needed to properly protect the gears, would be Lubriplate 105...and I agree with him. Its a grease/oil mix that keeps water out and will help protect the gears. I really really want to see more things like this for the hobby industry. Getting back to realistic is a must! Mike
                  I must agree that scale like boats are the way to go! I especially like boats up to about 36" long, as at my age they are easy to handle. I really must think about buying one of these drives then find a suitable hull (Challenger 31? ) This is the sort of look that I go for (jf the photo works!)
                  • SlickZERO
                    • Dec 2013
                    • 138
                    #54
                    Cell count
                    I can't seem to find it. How many cells? What is the Kv?
                    Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
                    • Tanner Basch
                      • Jul 2015
                      • 5
                      #55
                      Would you run these surface or subsurface
                      • Steven Vaccaro
                        • 8723
                        #56
                        its for 3s lipo.
                        http://www.offshoreelectrics.com/pro...rod=ose-B42515
                        • Tanner Basch
                          • Jul 2015
                          • 5
                          #57
                          can i run 2 of these on 3s or 4s on a 46 inch hull
                          • riflemanbtx
                            • Sep 2011
                            • 17
                            #58
                            someone should try this on 4S, my old TLF outer limits is a dog on 3S barely gets on plane... If it'll run 4 i'm sold. one quick question, if I could mount around a 2000kv motor to it, would 4S be possible?
                            • axel
                              • May 2007
                              • 127
                              #59
                              Well the specs say yes
                              • riflemanbtx
                                • Sep 2011
                                • 17
                                #60
                                whats the max RPM this drive system can possibly handle?
