Dual pickup rudder
  • vette 00
    • Jun 2015
    • 10
    Dual pickup rudder
    Just curious if someone who has experience with dual pickup rudders has any advice? Do they supply twice the water or should a person just run a separate pickup and leave the single pickup rudder alone?
  • lt130th
    • Apr 2014
    • 858
    They supply twice the fluid The inlets are dedicated to each channel within the rudder, so you have mass A through one line, and mass B through another line. Adding a transom pickup is an option if you don't want to change the rudder, but then you're introducing drag. In something like a catamaran, through-hull pickups work well, but I believe rudder pickups supply the most consistent flow due to being submerged most often.
    The next question is, "do I need a second pickup/cooling line?" If you're running an unmodified ready-to-run setup, it's generally not viewed as necessary to add cooling lines beyond the single-pickup rudder. If you're converting from single motor+ESC to twin motor+ESC, or upgrading the electronics to a "hotter" combo, then it becomes necessary. But heat is converted energy that your system is losing, so if you just want to keep things cooler, there is no harm in that.
    • vette 00
      • Jun 2015
      • 10
      Thanks lt130, I am looking for additional cooling without extra drag but wasn't sure about dual pickup rudder water volume. I will be giving it a try.
