Apparition Cat setup and discussion
  • Nikolas Andriop
    • Jun 2015
    • 73
    Hello.
    First of all sorry for my english
    Im a new member at the forum and i would like your help.
    I have an Apparition with TP Power 3640 2100KV with Seaking 120A and i have change the caps with the Rubycon 35V 1000uf and i solder the cables from esc to the motor
    I run it at 4S2p and the cable bridge is 10AWG and the batteries is Hard case 6000mah 60-120C
    The timing is 3.75 degree and i use M445 Octura
    The Temp after almost 5 min is 35 Celcius (95 Fahr) at motor and the Esc
    At the capasitors the temp is 85 Celcius (185 FAhr)
    The Weight of the boat ready for run is 2650grm (5.9 pounds) and the CG is 31cm (12.2 inches) from the back of the boat
    The Strut is 3mm below of the ride pads
    I was using the offset rudder but after some runs i realize that the rudder stays in the water and keep draging the boat slow.The same day i use the straight rudder and it was so big difference (No draging and more faster plain)
    Here is some photos
    Here is some videos
    This one is with the offset rudder
    Thanks!!!!!!!!!
  • Nikolas Andriop
    • Jun 2015
    • 73
    Also here is a test run with 5S
    The same setup but with a little higher temp at the motor and esc was 50 Celcius (120 Fahr) for a 5 min run
    The temp at the motor is in the rotor and i measured with leizer gun
    This one is the straight rudder and a test run with 5S
    • montymike
      • Jul 2012
      • 774
      Check with kfxguy. He builds rivercats same as apparition.
      He can give u tips on setup.
        I have no experience with those small 36mm can motors. I always run a 40mm can in mine. I'm sure you can get away with it on 4s but I think you need to do a few things:
        Change to a 442 or 642 prop
        Check strut depth. With the 42 mm the strut should be 2.5-3mm below the bottom on the sponsons. In other words put the boat flat on a table and move the strut down until you have a 2-3mm gap inbetween the rear edge of the sponson and table. Bout 1 degree positive angle on the prop.
        Make sure your wires are the shortest they can be within reason.
        Add a cap bank to it.
        Make sure you have a 2.5mm gap between the strut and drive dog
        Quality motor connectors and battery connectors is a must.
        I'd use 5000mah 50c batteries at the least. You could probably get away with 40c with a quality battery but I prefer to over do it.
        • montymike
          • Jul 2012
          • 774
          Also Check( hard core rc addict, )apparition rebuild they are the hobby king guys they put a sk 3660 1900 kv motor that ran good on 6s they showed the setup.
          • Nikolas Andriop
            • Jun 2015
            • 73
            The strut height is already 3 mm belon sponson and 1 degree
            I'll try the 2.5 mm gap between the drive dog and the strut
            My batteries is 6000mah 60 -120 C and the cable that connects them is 10AWG with hi amp plug
            Where I can put the extra cap bank???
            I already have change the 2 pieces factory cap from the esc with the 1000uf from the Seaking 180A
            I run now with the octura M445 but I was thinking to order the X442 M642and M640 so I can try them.
            Now I will order!!!!!
            I also have the Octura V942/3 ,V940/3 and a X440/3 CNC prop
            What is the advance of the offset rudder????
            What is yours boat weight rtr ( with hatch and batteries)???
            Thanks so much for your answers!!!!
            • Nikolas Andriop
              • Jun 2015
              • 73
              That is the characteristics of my motor
              7D wind
              Max Amp 110
              Max Voltage 30
              Continuous Watt 1650
              Max Watt 3300
                Most of these boats I've built weigh in the 9lbs to 9.7lbs range. Seaking 180 and tp 4060 was one good setup. It did 77mph with no problem. Might be overkill on the motor tho. A 4050 will work just fine. I maiden one today that did 50mph in play mode on 4s with a 1977kv motor turning like 22k rpm. It's setup to run 6s with a bit more prop for 80+mph. The offset rudder gets the rudder out the thust cone. When the boat is on plane and out the water, the bracket is not dragging like it does at low speed.
                • dmitry100
                  • Mar 2015
                  • 1264
                  kfxguy: Would it be a good idea to shorten battery wires? The stock revo wires do seem a bit long, especially I have to always scoot them so that they're not all over the place when I'm connecting them in series on each side of sponson. What is the purpose of shortening them anyway?
                    Shorter wires equal less resistance. Every little bit helps
                    • Nikolas Andriop
                      • Jun 2015
                      • 73
                      So I want to ask something about weight
                      You running at 9 to 9.7 lb
                      I'm running almost at 6 lb.This isn't to low weight for my boat???
                        The weight I listed is with two 3s 5500mah batteries included.
                        • Nikolas Andriop
                          • Jun 2015
                          • 73
                          And mine boat with 2 hard cases 2S 6000mah 60-120C include hatch is exactly 5.84 lb (2650grm)
                          That's even close to your weight.
                          When I use 5S is 6 lb of weight
                          My point is that I think my boat is so light and maybe I have to put some weight in it
                          • Nikolas Andriop
                            • Jun 2015
                            • 73
                            Hello.
                            I want to ask when i reduse porpoise???
                            When the prop is near or far from the transom???
                            At the Apparition what is the right position???
                            Thanks so much!!!!!!
                            • Nikolas Andriop
                              • Jun 2015
                              • 73
                              Anyone???
