Global Forum Users: Who Can Identify This Water Jacket?
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    OK, I know there are a lot of product gurus on this forum from around the world. Here is a challenge.
    Does anyone know who makes this water-cooling jacket? Are they still available and are they available in longer lengths? Also, are replacement o-rings available? This particular water jacket uses thinner o-rings than I've seen on any others and is also a very tight fit for even Lehners. This particular one in my possession is for a 36mm diameter motor.
    I greatly appreciate the help identifying the manufacturer and/or supplier!
  • RaceMechaniX
    • Sep 2007
    • 2827
    Ben,
    The O-rings should not be that hard to find. Pull one out from the shell measure the cross-section and look it up on McMaster. Manuel Wenny would likely know where that jacket came from. I believe he has a pair in a cat.
    TG
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • ron1950
      • 3024
      Dave can make almost anything u need of alum
        I have the orings that fit that. Pm your address and I'll send you some. They are 1.5mm thick 36mm id and 39mm od.
        • CornelP
          • May 2009
          • 745
          These jackets were originally made for Hopf, most of them with Tenshock sizes.
          Hopf closed shop years ago, but the guy that used to fabricate some of the stuff for him had a shop on Ebay. The name was CMT, but is also now extinct...
          • Meniscus
            • Jul 2008
            • 3225
            Thanks guys. It is greatly appreciated. I'll have to measure the o-rings if I can get them out without damaging them. I regularly affix water jackets to motors using various adhesives to avoid water leaks at higher speeds and higher pressure.
            As a side note, in my book, the loss of Hopf many years ago is one of the biggest tragedies to this hobby, especially for electrics. Some of those models had some of the best designs on the lower half that are still applicable today. Only minor modifications were required to the top for the increased speeds we see nowadays. The next is Schulze, but MGM has been stepping up their game to help fill that gap. Incidentally, many Hopf hulls and molds still exist today with other manufacturers around the world, so not all is lost.
            • CornelP
              • May 2009
              • 745
              You are so right...
              Some of his hulls are still available here:
              • Meniscus
                • Jul 2008
                • 3225
                I have measured the o-rings. The outside diameter is 0.006" or 1.5mm. The size measures 35.6 to 35.8mm.
                • axel
                  • May 2007
                  • 127
                  Hi
                  as allready said before manufacturer was Hopf.
                  What length are you looking for ?
                  I should have some fitting for Lehner or Vortex.
                  If you are interested pm me
                  take care
                  Axel
                  • Meniscus
                    • Jul 2008
                    • 3225
                    Thank you, it is greatly appreciated. I'm going to try the o-rings that Travis has available. The other motors I am running need a custom water jacket that isn't available for purchase. I believe I have those coming as well through a personal friend.
                      Email me your address. Going to the post office in the morning
