Thought I would share this. I am finishing a build for a boat to race Open Class Mono. It is a 50" Herzog Typhoon. Some of the last things I do is test the water lines for leaks in the tubing or the motor can etc. I also drop the boat in a tub and do a final leak check. So I am doing the water leak test on the lines and I cannot blow the water through the esc? Never happened before. So line section by section I am testing and I find nothing wrong. Then, I think, maybe it's the copper lines inside the esc itself. I take a small piece of servo wire and run it through and low and behold I find the tiny little piece you see in the picture completely blocking the water flow!!!! Had I not done the test, I would have lost a 300 dollar esc and probably never knew why.
Always test everything out before you run your boat for the first time!
