Drive dog slipping?
  • jakevisser10
    • May 2015
    • 100
    Drive dog slipping?
    I have tightened the drive dog on the flex cable many times, but each time I put a prop on and tighten it, it slides to the stuffing tube. The cable is the kintec upgraded cable for the revolt 30. Any suggestions would be appreciated.
  • kevinpratt823
    • Aug 2012
    • 1361
    Grind a slight notch/flat spot into the shaft where the set screw goes, try to leave a bit of a Ridge that the set screw would button against before it can slide closer to the tube.
    My private off road rc track
    https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
    • jakevisser10
      • May 2015
      • 100
      It already has a notch but the notch is pretty large and it just slides around in it.
      • kevinpratt823
        • Aug 2012
        • 1361
        Then bring the flex out of the coupling a bit so the notch is far enough out that it can stop the drive dog. Also make sure you have a locking prop nut, and don't try to over tighten it.
        • jakevisser10
          • May 2015
          • 100
          i think i just need a slightly larger allen wrench to tighten it down more. I am using a .050 size, which is getting stripped, but a 1/16 is too large :/
          • jakevisser10
            • May 2015
            • 100
            im going to try a new allen wrench before I take some of the cable out of the coupling.
            • Darin Jordan
              • 8335
              I consider Drive-Dogs and Flex Shafts disposable... So I generally remove the set screw, drop in some Loctite 603, and screw the set-screw back in. Done... It's never slipping or coming apart again.
              Think about it... how often does one REALLY take the drive-dog off? Glue it on and remove that failure point.
              Darin E. Jordan - Renton, WA
              • rickwess
                • Apr 2013
                • 777
                Same here but use 638 so the entire inner surface of the drive dog is bonded to the flex shaft. I then grind away any part of the set screw that's exposed and polish with increasingly finer grits of wet/dry sandpaper.
                  Bingo.
                  • jakevisser10
                    • May 2015
                    • 100
                    Turns out that loctite 603 is hard to come by, but I found it on Amazon and ordered a 10oz bottle. Thanks guys!
                      Napa sells it but red loctite holds up for me.
                      • jakevisser10
                        • May 2015
                        • 100
                        I tried all the hardware and auto stores around me and they only carry the thread locker for the most part
                          It's called sleeve retainer. It's some mean stuff. Red will work fine tho. Put some on the shaft where the drive dog will be, slide drive dog in place. Take set screw out. Put a drop on the screw and a drop in the set screw hole. Put screw in an tighten. Wipe excess loctite. Let sit over night. As long as you have a flat on the shaft that the set screw hits, I guarantee it won't come loose.
                          • jakevisser10
                            • May 2015
                            • 100
                            So I was randomly out tonight and passed by a napa that I didnt even know existed, so I just picked some sleeve retainer up. Just put it on. Ill let it sit for 24 hours and then we should be good to go! Thanks guys
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              Soldering is just as easy.
                              www.rcraceboat.com
                              jwohlt5362@yahoo.com
